Your TOP 5 Mods.
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Your TOP 5 Mods.
20 Jul 2006 23:38
#63563
1- Clear Fuel Lines & Inline Filter
2-Coil Relay Mod.
3-Carb Kits, Float Levels & Vacuun Carb Sync.
4-Starter/Head Light Lockout Relay Mod (save battery when I press on the Starter button).
5-Head Light High/Low Relay Mod (biger wires to Head Light).
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
21 Jul 2006 11:00
#63681
1)replace wire harness
2)replace seat
3)replace with pods
4)replace paint
5)replace the wife:woohoo: when see finds out that I bought the bike:whistle: that she says was a peice of crap:angry:
Just kidding abought the "peice of crap" part that is:laugh:
  • ltdrider
  • ltdrider's Avatar
21 Jul 2006 11:06
#63683
1. Dyna Coils
2. Dyna Electronic Ignition
3. In-Line Fuel Filters
4. Engine Case Savers
5. Load-Independent Flasher for the Turn Signals
I know it's kind of superficial compared to most everyone else, but Blaze is a resto, so welcome to my world.;)
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • wagonmaster69
21 Jul 2006 11:12
#63687
Hey ltdrider what are Load - Independent Flasher for the Turn Signals ?
  • RonKZ650
  • RonKZ650's Avatar
21 Jul 2006 12:13
#63698
They are call HD (for heavy duty)flashers. They are made for trailer towing. No matter if you have one light or 6 on the circuit they will flash at the same rate. Your original flasher depended on load to make it flash, meaning one burnt out bulb and the others will light but not flash because of the lower load. Get good HD flashers at a reputable auto store like NAPA. Don't go to Checkers or walmart, you'll get Chinese garbage that won't work even with the correct load.
  • fastestz1
  • fastestz1's Avatar
21 Jul 2006 12:42
#63709
1) TURBO
2) turbo
3) turbo
4) turbo
5) after market brakes!
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
21 Jul 2006 13:23
#63719
1) Throw suspension, wheels, brakes, tyres in skip and fit modern stuff
2) Fit 200hp turbo, intercooler and injectors
3) Throw melted pistons in skip, fit forged ones and bigger injectors again
4) Fit 300hp turbo
5) Fill tank with Sunoco 120+, open throttle and hang on...:silly: :lol:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • 1045
  • 1045's Avatar
22 Jul 2006 20:41
#63977
1. get rid of points,fit factory electronic ignition,coil mod......
2.gusset frame at neck, and everywhere else you can think of, tapered neck bearings
3. 4 into 1 pipes, rejet
4. front end and wheels off early 80,s kz
5. double disc's up front, fork brace...
1045
1045
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
22 Jul 2006 21:30
#63989
1. Kerker 4 into 1, K&N pods
2. Switched to Mikuni BS34 carbs
3. Switched to GPz fork
4. Rearsets
5. Fork brace
More in the works...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • Gman
  • Gman's Avatar
23 Jul 2006 07:16
#64023
1. Superbike bars
2. Switch to mini-blade fuses
3. Halogen headlight
4. Dyna S ignition
5. Good tires
These bikes are fun.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
23 Jul 2006 08:16
#64034
1. K&N Pod Filters with Stage 3 Jetting
2. Accel Coils and wires with Iridium Spark Plugs
3. 4-1 Header System
4. New tires(Dunlop GT501's)
5. New Chain and Sprockets
If I could sneak in another, it would be to "mod" the rider. Good riding ear, track days, and MSF Courses are a must. B)
'85 GPz550(ZX550-A2)
  • loudhvx
  • loudhvx's Avatar
26 Jul 2006 19:52
#65031
This is because the 1981 gpz 550 can get squirrely on ya with all that power and short wheelbase.
1. Fork Brace
2. Steering damper
3. Front springs
4. Rear shocks
5. Tapered head bearings
this stuff won't be any good without a new/good pice of rubber on the back from Goodyear/Pirelli/Metzler etc.
NO CHEN SHINGS or however they are spelled!
Then re-wire everything.
