Lowering bike....questions.
  • Torch
  • Torch's Avatar Topic Author
18 Jul 2006 01:03
#62800
How much can you safely lower the front of the bike by pushing the fork up through the triple? Im looking for about 1.5" of drop with minimal negative handling effects.
Whats the best way to go about lowering the rear? I haven't seen any lowering springs for these bikes anywhere, and theres really no room to re-drill holes for the shock mounts.
  • btchalice
  • btchalice's Avatar
Re: Lowering bike....questions.
18 Jul 2006 04:36
#62807
the front will lower till you hit the handlebars and on the rear you can use sportster shocks theyre about 2.5 inches shorter than stock
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
18 Jul 2006 06:24
#62850
I use 11" shocks on one of my bikes. I weigh 165 and if i hit a pot hole it will unplug the tail light. I like it low handles nice. Roy
  • donthekawguy
  • donthekawguy's Avatar
18 Jul 2006 07:26
#62870
For the front I used lowering tubes from schnitzracing.com. On the back I have a set of the lowering thinggys that move the bottom of the shocks back a couple of inches.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • kzmarvo
  • kzmarvo's Avatar
18 Jul 2006 12:39
#62938
What are lowering tubes?:blink:
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • wireman
  • wireman's Avatar
  • Visitor
18 Jul 2006 13:02
#62946
slugs in tubes.;)
  • rattler
  • rattler's Avatar
18 Jul 2006 21:47
#63055
they are talking about lowering weights that compresses the springs down further inside the forks thus lowing the front end. schnitz sells them. i would give ya the 2 inch lowering block i had on my stock swingarm i dont use anymore but i welded them solid:P. they are pretty cheap. they just push the bottom shock mount further back wich lowers the back.
Post edited by: rattler, at: 2006/07/19 00:47
  • Torch
19 Jul 2006 19:55
#63251
Only thing i worry about is how close to the ground my 4 into 1 is. It goes under the bottom of the bike, curves to the left side and then comes back out of the right. At stock height with my body weight on the bike, i have about 5" of ground clearance. If i lean to the left, it goes down even further.
  • rattler
  • rattler's Avatar
19 Jul 2006 22:14
#63276
5 inches:laugh: your still in the clear. with my bike standing straing up i only have 1 3/4" with vance hines 4-1 upswept pipe. but i have bottomed out two or three times:whistle:
  • wireman
  • wireman's Avatar
  • Visitor
19 Jul 2006 22:33
#63281
yeah with 10 1/4" rear shocks and tubes raised in trees had about 2" under vance and hines with my 200lbs:ohmy: my z1 will sit even lower frame wise but its a turbo so there is nothing below the frame to worry about.
Post edited by: wireman, at: 2006/07/20 01:41
  • donthekawguy
20 Jul 2006 07:54
#63370
rattler wrote:
they are talking about lowering weights that compresses the springs down further inside the forks thus lowing the front end. schnitz sells them. i would give ya the 2 inch lowering block i had on my stock swingarm i dont use anymore but i welded them solid:P. they are pretty cheap. they just push the bottom shock mount further back wich lowers the back.<br><br>Post edited by: rattler, at: 2006/07/19 00:47
Nope I was talking about the little tubes you put inside the forks. I had to rebuild anyway and got a set. Pretty cheap but you can make your own if you feel the need.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • Torch
20 Jul 2006 19:44
#63518
Im only worried about bottoming out in corners and unloading the rear tire. I can deal with banging in a straight line....wrecking i'd rather not deal with :lol:
I;ve got to looking at a set of clubman bars instead of clip-ons. I wonder if i could still lower the front forks 1.5-2" with the bars still on the front.
