Output sprocket identity ('84 GPz750)
  • OldRetroRider
  • OldRetroRider's Avatar Topic Author
26 Oct 2026 10:32 - 26 Oct 2026 10:33
#928701
Hi - I am looking at the different aftermarket drive chain sprockets I can find locally, and see that one front sprocket suggested for my '84 GPz 750 has type designation "JTR510.15".
At JT Sprockets website, this sprocket is listed to fit the GPz 750 Turbo model.
When checking various part diagrams from < www.kawasaki.com/ >, I see different part numbers for several bikes which, (based on my experience with many different BMW boxers, that share identical parts through a wide range of model and model years) actually could be identical. E.g.:
Model                part #
84 GPz Turbo   13144-1102
84 GPz 750      13144-1084
82 KZ 750        13144-1033
So my simple question is, are the sprockets for the above bikes actually, from the aftermarket suppliers point of view, identical, or interchangeable?
A 1984 GPz750 needing TLC once followed me home . . .
Last edit: 26 Oct 2026 10:33 by OldRetroRider. Reason: spell check
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Output sprocket identity ('84 GPz750)
26 Oct 2026 14:11
#928704
Model                part #
Interchangeable: yes
Identical: no
The Zx750A uses a front sprocket with a relatively large offset.  The Zx750E Turbo has wider gears and the output shaft is longer so the front sprocket doesn’t need offset.  Not sure about the Kz750 though.  I’m sure the spline design and count are all the same but putting a Turbo sprocket on your N/A model is going to move your chain line up front.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: OldRetroRider
  • OldRetroRider
26 Oct 2026 14:40
#928705
Model                part #
Identical: no
Many thanks, Doug - that's what I suspected. :-)
Without having the suggested parts in front of me, so I can check what the alignment of the final assembly will be, I'm going to look elsewhere for parts.
