Nov 1: Still struggling to get pressure in my front lines
  • asphalt900
  • asphalt900's Avatar
Re: Nov 1: Still struggling to get pressure in my front lines
02 Nov 2025 03:38
#918594
Speaking of "trapped" air bubbles. If your master cylinder banjo bolt/line is higher then your master there will be air in there too. Remove master cylinder and position lever high or "burp/crack" the bolt to let that big-o-bubble out.
  • Bobf
  • Bobf's Avatar
  • KZ1000A3A
02 Nov 2025 19:32
#918643
One way that has worked in the past for me - after following all the others' advice herein - .  Place bike on the side stand and turn handlebars full left to raise master cylinder all the way up.  Start pumping; slow deliberate squeeze, quick release.  Vibration from the lever return can break stubborn air bubbles loose and cause them to migrate to the master cylinder. I've worked out many 'resistant' bubbles this way.  You should feel the pressure build up after a few cycles.
Bob F.
EKKAWI
1976 KZ400D, 1977 KZ1000A1, 1976 KH400, 1979 XS400, 1980 KZ550A, 1980 KZ750E, 1983 GPZ550,1979 KZ1000B LTD, 1986 ZG1000 Concours,1982 XS650 Turbo,KZ1000C, KZ1000P,1978 KZ650C (×2),2003 BMW R1150RT
2014 BMW R1200RT (Current ride)
1971 Norton 750 Commando
1979 KZ1000A3A MKII (Present project)
