76 Z1 rear wheel, are there other bikes that match it?
  • Bikeazoid
  • Bikeazoid's Avatar Topic Author
24 Nov 2024 17:41
#906387
Hi, I have a 76 Z1, someone at one point put a 15 inch rear wheel on it.  I've been looking for a standard rear wheel for it, but they are hella expensive if you can find them.  I was wondering if another Kawi had the same wheel I can use, like a KZ750 or something.  Thanks all.
  • Cra-z1
  • Cra-z1's Avatar
Re: 76 Z1 rear wheel, are there other bikes that match it?
24 Nov 2024 17:47 - 24 Nov 2024 17:47
#906389
More than likely it is a 16 inch rim. Many bikes in those early years were laced to a 16 inch rim. Im assuming it is a spoke rim. If so all you need to do is buy a used 18 inch rim from any of the bikes from 73-76. A new rim is not that expensive. You will need spokes also to replace it to the 18 inch rim. I have a pretty good rim if chose to go that route. Where are you located.
Last edit: 24 Nov 2024 17:47 by Cra-z1.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
24 Nov 2024 18:46
#906390
Question about year and model. Not that I know correctly but I do not think the Z1 was offered in 1976. As I understand it the Z1 was offered as a 73, 74 and 75 model . For 76 they marketed both (K)Z 900 in A and B (LTD) models but not as Z1 models.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Cra-z1
  • Cra-z1's Avatar
24 Nov 2024 18:53
#906392
Yes if it is a 76 its a KZ either way they used (Z1 and KZ)the 18 inch spoke rim
  • hardrockminer
  • hardrockminer's Avatar
25 Nov 2024 04:39
#906400
I think the KZ900 LTD used a 16 inch rim.  Which makes me wonder if the author has an LTD?  If he looks down at the valve stem he will see the rim date code.  It would be useful if he could post a photo of it.
  • Cra-z1
  • Cra-z1's Avatar
25 Nov 2024 07:42
#906402
We really don know what he has at this point. The LTD did use the 16 inch rim (mag wheel) but the std kz900 used 18 inch spoke wheel.
The following user(s) said Thank You: hardrockminer
  • Kaw-boy 900
  • Kaw-boy 900's Avatar
  • Let the Good ''Old'' Time Roll !
25 Nov 2024 15:43
#906409
That explain why wheelies were easier with my LTD than my KZ :)
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
  • Bikeazoid
25 Nov 2024 17:17 - 26 Nov 2024 00:26
#906414
Thanks Cra-Z1, I'm in Orange County, like 30 miles south of Los Angeles.
HardRockMiner, no LTD, it has a chain.  I had an LTD 1000 in like 93, got it at a yard sale for 30 bucks!!!!  I wish I still had it.
OK, sorry on the lag, new to this site so I'm still struggeling finding out how to post and how to post pix, and how to get pix from my phone to my computer.
Also don't ding me on the condition, I was driving in my neighbor hood and saw the tail light in a guys garage, and I knew what it was.  Owner hadn't run it sinde 1989 it just sat in his garage.  I pushed it home after giving him $500.  I gave him the seat back since I'm not into vintage Dennis Kirk and he wanted to so something with it.
Thanks all for helping out, this is really fun, My Katana project ran amock when my Bandit 1200 doner bike got stollen.
Last edit: 26 Nov 2024 00:26 by Wookie58.
  • sf4t7
  • sf4t7's Avatar
25 Nov 2024 19:24 - 25 Nov 2024 19:25
#906415
That rear wheel may have been made by using the original hub laced to a smaller rim.  I don't think any of the LTD's had spoked wheels, but others may know more about that.
And welcome to the fun!
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 25 Nov 2024 19:25 by sf4t7.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
25 Nov 2024 19:57
#906417
You should check out Buchanan's.  They are the only place I know of that specializes in spoke wheels, and they happen to be not far from you.  They sell rims in all sizes, spoke kits, and they build wheels as well.
www.buchananspokes.com/products/spoke_kits_kawasaki_kz.asp
Given that you already have the correct rear hub, if you can afford it I would take that whole rear wheel over to Buchanan's and buy one of their 18" rims, then have them build it up as a new wheel.  It'll be cool!
Although, if you end up with a nice aluminum rim, you might have to rebuild the front wheel as well so they match.  :)
My dad's '74 Z1
'00 ZRX1100
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
26 Nov 2024 00:29
#906421
I have fixed your pics (next time before you post click "install all") not sure about your "chain reference" to the best of my knowledge all the KZ900 and 1000 models are chain (1100 is shaft)
  • asphalt900
  • asphalt900's Avatar
26 Nov 2024 02:16
#906424
Nice find! Did You feel Youthful pushing it down the street, ha. If it were me i'd just find an original 40 hole "steel" Takasago 2.15" 303-5 rim, new set of "swagged" spokes and nipples. Then hunt down a wheelwright for assembly. As mentioned Buchanan or actually a bicycle shop tech that laces wheels for a living.  Because the hub is even on both sides, you'll only have two type of spokes to buy, 20 inner, 20 outer. And there's no weird offset, rim and hub have equal offset. Those old 16" chrome rims were popular back in the day, a Harley aftermarket part actually. So the Seat and rim were probably bought from the J C Whitney catalog rather then the "later Dennis Kirk" company. Nice to see you still have the "often missing" original airbox! Your fun is just Beginning, Good Luck!!
