- Thank you received: 44
Center Stand
- tomsbadkz
14 Jul 2024 14:20 #902107
by tomsbadkz
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Bored throttle bodies
Center Stand was created by tomsbadkz
Just kind of curious why someone would cut off center stand bracket so no center stand can be used to put an exhaust on that has to be completely removed just to change the oil.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- Thank you received: 2301
14 Jul 2024 14:30 #902109
by Wookie58
Replied by Wookie58 on topic Center Stand
Would it not be easier to use a paddock stand than mess about re-fitting a main stand for this purpose (my brackets are still in place as this is where my lift picks up from)
- Thank you received: 2059
14 Jul 2024 14:37 - 14 Jul 2024 14:43 #902110
by Scirocco
Replied by Scirocco on topic Center Stand
Because they can or are not the brightest candle on the birthday cake.
See a lot of stupid repairs, fixes, mods, upgrades, conversions, stupidities of so called wanna be mechanics @ Youtube channel "Just Rolled In"
Last edit: 14 Jul 2024 14:43 by Scirocco.
- willemZ900
- Z1B 4 ever
- Thank you received: 56
15 Jul 2024 03:52 #902134
by willemZ900
Replied by willemZ900 on topic Center Stand
I use the centerstand only in wintertime when the Z is sleeping or when i want to change tires. The paddock stand is for oil change or chain cleening/ajustement. I dont understatement People Who cut of the brackets.
- tomsbadkz
15 Jul 2024 06:01 #902137
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Replied by tomsbadkz on topic Center Stand
Yea, i generally use my lift for oil changes and such, but i like having original stand. If id have issue along the road and need wheel off the ground for a broken chain, etc. Thanks guys. Just wanted to ask others cause the guy i bought the bike from had a shit fit cause i took off the exhaust he had on it. Like i said, couldn't even change the oil without total removal.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- slayer61
- KZR FLAG RELAY CARRIER #62
17 Jul 2024 08:50 #902260
by slayer61
Replied by slayer61 on topic Center Stand
I have a full collection of paddock stands, and I cut off my center stand lugs to clear the exhaust on my Suzuki. I have to drop the exhaust anyway to change the oil. To me, it's no big deal
- Cra-z1
- Thank you received: 122
17 Jul 2024 15:58 #902283
by Cra-z1
Replied by Cra-z1 on topic Center Stand
Then you got the guys who cut off everything to save weight
- tomsbadkz
17 Jul 2024 16:02 #902284
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Yes , i'm sure that will make a difference on a six hundred pound motorcycle
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- sf4t7
- Thank you received: 348
17 Jul 2024 17:19 - 17 Jul 2024 17:20 #902286
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic Center Stand
My center stand became a shop tool 40 years ago when installing my Kerker (now it's installed only for oil and filter, tire, and chain / sprocket changes). Didn't notice any performance gains from the slight weight reduction
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Last edit: 17 Jul 2024 17:20 by sf4t7.
- Kelly E
- Thank you received: 334
17 Jul 2024 17:31 #902288
by Kelly E
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
Replied by Kelly E on topic Center Stand
I installed a center stand on my 77' KZ 1000LTD because it didn't come with one but has the mounting brackets. It had the dealer mounted Kerker that was trashed. I replaced it with a stainless steel Delkevik that allows you to use a center stand.
No center stand on a chain driven bike kinda sucks.
1983 Honda CB 1100F
And more
- tomsbadkz
17 Jul 2024 17:37 #902289
by tomsbadkz
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Yeah, I kept the brackets on my pro street KZ and can just slide the bolts in and use the centerstand at the house if I need it. Its not designed for long rides. Race gas mix and big block cylinder. Doesnt like hot summer days much.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
18 Jul 2024 01:01 - 18 Jul 2024 01:02 #902292
by Wookie58
I guess it also depends how you use your bike. I can't speak for my KZ (yet) but many other bikes I have ridden had a tendency to "ground" the main stand on left hand bends which can be exciting
I guess this isn't an issue if your bike is set up for straight line performance
PS: real nice GPZ
PS: real nice GPZ
Last edit: 18 Jul 2024 01:02 by Wookie58.
