1977 1000 A1 forks
- Pattenrd
1977 1000 A1 forks
04 Sep 2023 09:34
Restoring a A1 took forks apart to powder coat lowers when i took inner tubes apart to check spring discovered two different types one with long dampener rod and long spring and one with short rod and spring it looks like 77 had short rod any information would be appreciated ito identify without taking apart large swap meet coming up would like to make it correct
Re: 1977 1000 A1 forks
04 Sep 2023 11:00
Checking Partzilla, it looks like 77 has the same internals as 76 and 78. Probably 79 and 80 as well.
The following user(s) said Thank You: Pattenrd
04 Sep 2023 17:33
04 Sep 2023 19:33 - 04 Sep 2023 19:34
I’ve got a set of ‘77 A1’s on the bench right now, the only difference is in the color of the dampner. One is silver and the others is gold. Must have been something a PO did. Maybe one was damaged and they replaced it without tearing them apart and never knew they were a miss match.
Last edit: 04 Sep 2023 19:34 by Mikaw.
05 Sep 2023 04:06
Those look real nice!!
- Pattenrd
05 Sep 2023 08:58
No way guy road on street don't think he knew what he had
- Pattenrd
05 Sep 2023 09:02
What is the spring length did you disassemble through botton by removing c clip or just take out of the top you think the 76 tube would work thanks for the help
05 Sep 2023 14:56 - 05 Sep 2023 14:59Fork lowers were vapor honed (blasted). Recently rebuild two set of Z1 forks for Wheelhop at our Zukey Lake get together. Same guy did/does my blasting.Those look real nice!!m
Last edit: 05 Sep 2023 14:59 by Mikaw.
05 Sep 2023 15:05 - 05 Sep 2023 16:02What is the spring length did you disassemble through botton by removing c clip or just take out of the top you think the 76 tube would work thanks for the help
EDIT
Removed FSM page. Information was incorrect for this post
Last edit: 05 Sep 2023 16:02 by Mikaw.
- Pattenrd
05 Sep 2023 15:14
Thats what i thought I'll check clymer manual again ive done a 78 b2 and a 74 z1and they were both long dampener spring length would help thanks for your information
- Pattenrd
05 Sep 2023 15:23
Z1 forks and 77 kz forks are different ive done a couple z1 and a 78 b2 77 has short dampener rod. forks look real pain real nice going to vapor blast covers guy i got bike from painted whole motor and cases black. Thanks
05 Sep 2023 15:25 - 05 Sep 2023 16:03Mikaw wrote: Mikaw
EDIT, REMOVED INCORRECT INFO
Last edit: 05 Sep 2023 16:03 by Mikaw.
