Rust and pitting on fork tubes
  • ckahleer
  • ckahleer's Avatar Topic Author
03 Jul 2023 20:18
#886799
I was looking to replace the fork tubes on my recently acquired 79 KZ400, but the used ones I see on E-bay don't look much better than mine. I don't want to put the money into NOS tubes. The section of tube that slide on the seals are OK.
My plan is to put on Gator fork boots and chrome vinyl wrap on the tubes between the triple tree clamps. I'm not restoring this bike, just want it to look better as an occasional errand runner.
Any other ideas I should consider?
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Rust and pitting on fork tubes
03 Jul 2023 23:36 - 03 Jul 2023 23:37
#886800
You could sand them with 1000 grit (not the the functional section that runs through the seals) apply a rust-inhibitor and then polish. Would make them look a lot better and slow the rusting process
Last edit: 03 Jul 2023 23:37 by Wookie58.
  • hardrockminer
  • hardrockminer's Avatar
04 Jul 2023 03:33
#886802
Maybe a new seat cover?
The following user(s) said Thank You: Warren3200gt
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
04 Jul 2023 05:22
#886804
I would definitely try to sand out the rust. You'll still have pitting but I've heard of a technique where you sand with crumpled up aluminum foil and WD40 to remove some of the pitting. It's worth a try.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • martin_csr
  • martin_csr's Avatar
04 Jul 2023 05:36 - 04 Jul 2023 05:51
#886805
Did you try searching KZ440 forks?  In case you aren't aware, the 400 Ltd has the same fork tubes as a number of 440 Ltds, so there should be more available for the 440.
Last edit: 04 Jul 2023 05:51 by martin_csr.
  • urankjj
  • urankjj's Avatar
04 Jul 2023 06:03
#886806
On the forks you could try soaking with wd-40 or simular, and then using some 0000# grade steel wool and metal polish.  Make sure you use only 0000# steel wool. I have used it on both chrome parts and glass windshields with no scratching at all and excellent results.
  • Warren3200gt
  • Warren3200gt's Avatar
04 Jul 2023 07:25 - 04 Jul 2023 07:28
#886807
Yep, ultra fine steel wool and chrome cleaner then seal with a wax.
Battery acid burns on an original 650 exhaust.
After
Before
Last edit: 04 Jul 2023 07:28 by Warren3200gt.
  • Nessism
  • Nessism's Avatar
04 Jul 2023 07:58
#886812
No disrespect to Warren, but notice the scratching in the After photo.  That's why I use straight chrome cleaner on a rag, and rotate the rag often, otherwise you will be grinding oxide material into the chrome, scratching it.  Good news with fork tubes, though, is they are HARD chromed, not cosmetic chrome like an exhaust pipe.  You won't scratch hard chrome nearly as easily, so the 0000 steel wool will be okay.
  • Warren3200gt
04 Jul 2023 08:11 - 04 Jul 2023 08:12
#886813
Nessism, are you looking at them the right way round? The After pic is the top one.
The scratches and majority of the acid burn discoloration on the before pic are all but gone on the after (top) pic.
Admittedly not 100% but loads better.
Zoom in on each pic to clearly see how diminished they are.
Last edit: 04 Jul 2023 08:12 by Warren3200gt.
  • hardrockminer
04 Jul 2023 17:05
#886840
He asked...any other ideas I should consider?  I thought I'd inject a little humour!
As for the fork uppers...they are hard chromed.  Some shops will re-chrome them.  Most won't.  A new set probably costs around $100 US.
  • ckahleer
04 Jul 2023 20:12
#886849
Is this more humour?
1997 ZL600
94 KE100
82 KZ305
74 TC185
