Wheel bearing question
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Wheel bearing question
20 Jun 2023 14:04
#886236
If you have a heat gun to heat the cavity, it will be easier to fit the bearing.
That helps bigtime.
Also freeze the bearing and between that and heating up the hub the bearing will almost fall into place!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: MLMG
