76 KZ900 A4 Largest tire to fit rear wire spoke rim?
Re: 76 KZ900 A4 Largest tire to fit rear wire spoke rim?
27 Jul 2022 09:34Back then, (the 80s), I got the Akront rim and spoke kit from Kosman Specialties and had them lace it up also. Never had any problems with clearance or handling. R.I.P to Sandy Kidman who passed away this year. Interesting piece on him here. Good luck on your build. www.dragbike.com/top-fuel-motorcycle-legend-sanford-kosman/
WOW Thanks for the link on Sandy Kosman
It was a real ride down memory lane
The following user(s) said Thank You: urankjj
- Kidkawie
- I bleed premix
27 Jul 2022 13:09
I have a 140 on a 3.5" rim laced to a stock hub, stock swingarm on my Z1b.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
27 Jul 2022 13:56 - 27 Jul 2022 13:57
I was running 130 on a 18 x 3.50" front and 180 on 18 x 5.75" rear Akront rims in the late 90th. Wheels are for sale next...
Last edit: 27 Jul 2022 13:57 by Scirocco.
- DOHC
- Those Doe-Hawks really go!
27 Jul 2022 15:15 - 27 Jul 2022 15:18The difference is that the LTD has a 16x3" wheel, while the 76 spoke wheel is 18x2.15". That extra rim width allows for a wider tireI have a 150 on my 78 LTD so I was hoping for something similar on the wire spoke for the 76
If you're willing to get a wider rim then you have a lot more options, until the tire starts to contact the swing arm or the chain. Then you need a wider arm and an offset sprocket. How many parts do you plan to replace?
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 27 Jul 2022 15:18 by DOHC.
The following user(s) said Thank You: Irish Yobbo
- Olbeedo
28 Jul 2022 13:16
I am gonna have to get a wider rim the stock one is tiny even compared to my other KZ, I wanted to use the drum brakes but I think i'll have to switch to disc to use a larger wire rim.
OlBeedo- KZ for Life........................
