1981 KZ 1000 LTD trees interchangeable with 1978 KZ 1000 LTD?
  • 750 R1
  • 750 R1's Avatar
Re: 1981 KZ 1000 LTD trees interchangeable with 1978 KZ 1000 LTD?
22 Feb 2022 14:06
#862772
You CAN NOT spread the triple clamps to fit larger diameter forks, you risk the clamps failing and ending in disaster. It sounds like you have no idea what you are doing, the front end is designed around the frame geometry, simply bolting, or trying to bolt on foreign parts is not the way to do it, unless you have some understanding of suspension geometry.
Rebuild your original forks.....
The following user(s) said Thank You: LATER
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
22 Feb 2022 15:40
#862778
The upper and lower triple do clamps the fork legs by form (max. clamping surface) and pressure. You can do a +1,00 mm over size bore but this can weaknesses the triples.
Do not play any games with you health.....
  • LATER
  • LATER's Avatar Topic Author
23 Feb 2022 06:14
#862806
Thank you, everyone, it was just a thought.
