Eesh, I have to keep going back and re-checking the thread, it seems like every time I type up a reply someone else posts at the same time and I keep missing things.
And I need to check those videos. So ok, it sounds like maybe I can leach the upper tubes mounted to the bike but I'll need to pull the top caps and remove the springs, and of course drain the remaining oil before starting. I'll also need to hose everything down really well before I start, to try and get most of the oil splatter off the forks. Then I can wash them down a little better again once everything is reassembled so that I can see if they're still leaking or not next time I go for a ride. I do have a small air ratchet and can easily pick up a metric hex head if I have any trouble getting the allen bolts free, thanks for that.
Meanwhile I also had to pick up a new rear brake caliper off ebay. I discovered last year the current one has a groove inside the cylinder wall and when the pads wore down the cylinder would catch and wouldn't release. It never locked up on me, but I started noticing some occasional significant drag. Figured I'd just swap the whole caliper, I wouldn't sure if that was even worth trying to repair. Got a big storm heading in this weekend though, with temps moving back towards the 40's (and possible overnight snow!), so I won't be missing any good riding weather while waiting for parts to arrive. Other than these two issues the bike has been running pretty decent. I forgot to store the battery in the garage this Winter, but still had plenty of juice to try and get it started up last weekend. I love it when things just work.
