Mounting tires proper way
  • katit
  • katit's Avatar Topic Author
27 Jan 2021 11:53
#842514
Any know how or pointers to correct tools to use? And procedures? In general, how do you mount and remove tires so the rim does not get scratched or indented?
I am guilty of doing it myself so I want to learn correct procedure.
Videos on youtube clearly showing people sticking metal screwdrivers and so on marking and scratching rims.
Re: Mounting tires proper way
27 Jan 2021 12:55
#842520
I use a pair of Motion Pro rim protectors and two 11 inch Motion Pro tire irons. Ed
The following user(s) said Thank You: Nerdy
  • Kaylinator
  • Kaylinator's Avatar
27 Jan 2021 13:32
#842523
Watch this video, starting at about 12:48.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
The following user(s) said Thank You: DOHC, Mikaw
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jan 2021 14:11
#842525
It depends on the tire-rim combo.
Sometimes the tire is too tight to put on with tire levers.
I ruined a set of Michelins by damaging the beads with levers.
The next set I had CycleGear use their tire machine and they still had trouble.
He had to put the tires in a hot summer car to soften them up.
Granted it's a tubeless tire on a tube rim.
(Michelin Commander II on KZ440 D2 stock aluminum rims)
81-KZ440-D2.
LIC, NY
  • Mikaw
  • Mikaw's Avatar
27 Jan 2021 14:18
#842526
Kaylinator Now you post this. :silly: I needed this about 5 weeks ago.
Seriously thought thank you. I never knew the bead protector when under the band. Great post.
  • Kaylinator
27 Jan 2021 14:50
#842530
Mikaw wrote: Kaylinator Now you post this. :silly: I needed this about 5 weeks ago.
I sort of just assume that if you're on this forum, you'd follow him on youtube as well. That man is a genius.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Nerdy
  • Nerdy's Avatar
27 Jan 2021 15:24
#842534
650ed wrote: I use a pair of Motion Pro rim protectors and two 11 inch Motion Pro tire irons. Ed
Thank you for the tip!! I didn't know rim protectors were a thing but now I need some. :)
The KZ440B project bike has powder-coated rims and I was worried about installing the tires. The original plan was to coat the tire irons in Plasti-dip but I wasn't sure how well that would hold up.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • ghostdive
  • ghostdive's Avatar
27 Jan 2021 17:54
#842538
I think I've seen a people use pieces of milk jugs in lieu of proper rim protectors - I've never tried, my wheels aren't painted.
Aside from lots of lubricant (soapy water works well in my experience) I highly recommend getting the tires as hot as you can (within reason). I leave them in the sun for about an hour if the weather allows.
2001 ZX-6R
  • martin_csr
  • martin_csr's Avatar
27 Jan 2021 18:56 - 27 Jan 2021 18:58
#842540
By Nerdy: Thank you for the tip!! I didn't know rim protectors were a thing but now I need some. :)
I doubt Plasti-dip will hold up at all. The first time doing the job I used milk jug plastic >> large pieces folded in half. Then I got some rim protectors which make the job much easier. see pic. The milk jug plastic tends to move around. no big deal, but kind of a pain.
Last edit: 27 Jan 2021 18:58 by martin_csr.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
28 Jan 2021 13:23
#842576
Practice.
Theres more involved than just slapping on a new tire. First, throw the tube protectors in the trash. You should run 2-3 layers of quality duct tape in its place. Use baby powder on the tube and inside the tire so the tube doesnt get bunched up. I use the 3 lever method. Been doing MX tires for 30 years, street tires are easy as F. Front tires barely need spoons.. Line up the yellow dots with the valve stem.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • F64
  • F64's Avatar
  • 81-KZ440D2
28 Jan 2021 14:57
#842586
If you have aluminum wheels, do not use soap.
The soap will cause the aluminum to corrode and pit.
The first place that mounted my tires used this.
If you're having issues you may be able to get a small amount from a motorcycle shop as 11lbs will last a couple of lifetimes.
www.wurthusa.com/Chemical-Product/Tire-R...1-Lb-Pail/p/08901221
81-KZ440-D2.
LIC, NY
28 Jan 2021 15:36 - 28 Jan 2021 15:38
#842588
Kidkawie wrote: Practice.
I always use the tube protectors (rim locks). Why, one might ask? This is because many years ago on my BSA, which did not have rim locks, the rim slipped a tiny bit some number of times inside the rim until eventually this slippage caused the the rim to clip off the tube's valve stem. This happened when shifting into top gear in heavy traffic. Needless to say I was extremely lucky that the idiot directly behind me didn't hit me when my rear tire immediately went flat causing the back of the bike to swerve radically and violently from side to side. He thought I was doing it on purpose!
I don't know if modern tires on the Kawasaki might slip a little inside the rims. Maybe they won't or maybe they will, but considering the tiny extra time it takes to install the rim locks I'll keep using them. Ed
Last edit: 28 Jan 2021 15:38 by 650ed.
