1983 KZ440 Brake Line
  • martin_csr
  • martin_csr's Avatar
Re: 1983 KZ440 Brake Line
28 Jul 2020 07:48 - 28 Jul 2020 16:46
#831704
The diagrams at Partzilla show the lengths of the long single line & the upper line for the dual line setup. I'm pretty sure the measurements are eye-to-eye. That's what they are for my motorcycle anyway. my csr has 2 lines & I got the same length lower line. To figure out a shorter upper line after installing new bars, I disconnected the brake joint at the forks & lowered it until the line looked right, then measured & subtracted the overage. I ordered a line that was a couple inches longer than needed so that the m/c can be disconnected & moved out of the way to allow room for servicing or changing bars or whatever.
Last edit: 28 Jul 2020 16:46 by martin_csr.
The following user(s) said Thank You: Grcko
