1980 D3 Z1R Front Master cylinder
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1980 D3 Z1R Front Master cylinder
17 Mar 2020 19:14
#821130
In some rar cases i had to use a Syringe on the bleeder to press the brake fluid from the caliper to the MC. Air bubbles goes easier up than down the brake line:whistle: :whistle: :whistle:
The following user(s) said Thank You: martin_csr
  • Rick H.
  • Rick H.'s Avatar
18 Mar 2020 06:49
#821145
Are you keeping the end of the hose on your brake bleeder submerged in brake fluid as you go through the bleeding process?
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • martin_csr
  • martin_csr's Avatar
18 Mar 2020 07:36 - 18 Mar 2020 07:37
#821148
By Scirocco: In some rare cases i had to use a Syringe on the bleeder to press the brake fluid from the caliper to the MC. Air bubbles goes easier up than down the brake line.
In case it needs to be said, he would have to temporarily remove the MP mini-bleeder, then re-install it to bleed the brakes.
Or he could unbolt the caliper, shim the brake pads as tight as possible, and elevate the caliper with the bleeder nipple pointing upwards >> this is how I've done it. mine is just a single disk, so I haven't had any problems doing the job.
Last edit: 18 Mar 2020 07:37 by martin_csr.
The following user(s) said Thank You: Scirocco
  • 1980 Z1R D3
  • 1980 Z1R D3's Avatar Topic Author
  • A young gun with a taste for two-wheeled fun!
21 Mar 2020 11:08 - 21 Mar 2020 11:10
#821306
Thanks for all your help everyone, it turns out that it was the amount of free play in the cable. The cable tension adjuster was on too tight and it wasn't letting the piston travel all the way to the end of the bore and collect the brake fluid. Loosened the adjuster to allow for the factory setting of free play at the lever and the lever firmed right up and the brakes functioned perfectly.
1980 Z1R D3
Last edit: 21 Mar 2020 11:10 by 1980 Z1R D3.
