Rear brake dragging. 12 Jan 2020 10:57 #816968
  • Caleator
  • Caleator's Avatar Topic Author
  • Thank you received: 5
I'd like to report that it's retracting properly now.
mixture of a really deep cleaning and the red rubber Grease seems to have done the trick.
thanks for all the help
1981 Kawasaki GPZ550 (KZ550D-1)
Rear brake dragging. 12 Jan 2020 12:18 #816976
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
Good to hear....
The following user(s) said Thank You: Caleator
Rear brake dragging. 12 Jan 2020 21:15 #817001
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Mikaw wrote: Good to hear....
+1
Rear brake dragging. 13 Jan 2020 14:18 #817039
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
You can have a similar malfunction, as I found out the hard way, if you adjust the pushrod to eliminate too much of the freeplay, you can accidentally adjust it to the point that the master piston is being pushed just past the bleed hole. The rear brake will still seem to work properly... braking and releasing as expected. But as the fluid heats up a bit, the brake will get applied increasingly until it locks up. Then the only way to release it is to shorten the pushrod back to normal.
As a side note, there is no rebuild kit for the rear master on your bike, and there is little to no availability for good used ones anymore. Every one I tried 10 years ago was pitted. But luckily, you can modify a Ninja 250 rear master to work without too much trouble. You will have to fabricate some spacers and modify the pushrod, but it works great... like new.
