Struts 80-83 kz440
- M_a_t_t
Re: Struts 80-83 kz440
29 Mar 2019 08:40NewYorKZ440 wrote: thanks for the info you guys are awesome
i don't know if i'm imagining this wrong but how you lower the forks sounds pretty counter intuitive lol
Think about it like this, the forks stay stationary. You slide the frame (triple trees) down the fork tubes
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
29 Mar 2019 08:49 - 29 Mar 2019 08:53
Struts are also used on drag racing bikes to control weight transfer to the rear.
If you raise the fork tubes, be certain that there will be no contact between the wheel / fender combo and the frame or exhaust pipes when the suspension is fully compressed. That sort of contact might result in an ambulance ride.
Last edit: 29 Mar 2019 08:53 by TexasKZ.
- NewYorKZ440
29 Mar 2019 20:53TexasKZ wrote: Struts are also used on drag racing bikes to control weight transfer to the rear.
ok i see so struts can hold an advantage over shocks at the strip ? and thanks i would never think to check that
