1980 KZ550 C1 LTD Swing Arm Bearing and Sleeve Replacement
- LouisDePasquale1980KZ550C
19 Jan 2019 17:04 - 19 Jan 2019 20:56
Hey guys, hoping to tap the KZ Fountain of Knowledge. I tore my swing arm apart; And found a bad bearing and a grooved sleeve. I have the needle bearings ordered but can't find a sleeve anywhere. Ebay had one but was far worse off than mine.
Does anyone know where I could find one?
Would another model's sleeve work?
Are these sleeves hardened? If not then I could weld it and put it on the surface grinder.
Appreciate any info you can throw my way.
1980 KZ550 C1 LTD
Central New York
Central New York
Last edit: 19 Jan 2019 20:56 by LouisDePasquale1980KZ550C.
Re: 1980 KZ550 C1 LTD Swing Arm Bearing and Sleeve Replacement
19 Jan 2019 17:19
Take a look at the link below. If the info it contains is accurate the sleeve on the 1980 KZ550-C1 is the same that was used on quite a few models. Ed
www.partzilla.com/product/kawasaki/42036-1018
19 Jan 2019 17:35 - 19 Jan 2019 18:06
No eBay APP ID and/or Cert ID defined in Kunena configurationSorry 650ed, part# 42036-1018 no longer available for all other Kawasaki models but here
go and buy fast
Edit:
or you do a needle bearing conversion from HK2216 to HK2016 with SUZUKI sleeves, need some metal work.
go and buy fast
Edit:
Last edit: 19 Jan 2019 18:06 by Scirocco.
19 Jan 2019 19:13
That sleeve in in the UK and I am in Central New York. Unfortunately I've had too many problems buying internationally through eBay. Looking to find a part that is closer to home. Doing my own machining would prob be cheaper than the shipping alone. LOL. Speaking of metal work. Scirocco, you mentioned changing needle bearings and switching to a Suzuki sleeve. But said some metal work would be involved. What would need to be done. Opening up or bushing down the swing arm to accommodate the different bearing? Shortening the sleeve? Both?
Although I am just thinking of filling the worn area with weld and surface grinding it to the proper diameter.
1980 KZ550 C1 LTD
Central New York
Central New York
19 Jan 2019 20:16 - 19 Jan 2019 20:32
Well after a little more research; I found a website that lists 20 different bikes that use this same sleeve. So anyone owning these bikes may have a hard time finding a replacement too. And the list only included bikes from 1984 to 1996. Seems like a part that was used for at least 16 year would be easier to find. I guess not. lol
1980 KZ550 C1 LTD
Central New York
Central New York
Last edit: 19 Jan 2019 20:32 by LouisDePasquale1980KZ550C.
20 Jan 2019 08:33
Your swing arm sleeve ID = 14 mm / OD = 22 mm
This Suzuki sleeve has the same ID/OD, 2 x € 10.50
www.cmsnl.com/suzuki-gs550e-1981-x-e01-e...145001/#.XESdRrmWw_w
Shorten your old grooved sleeve parts on both sides on a lathe by the lenght of the new Susuki sleeves
Your old sleeve work like an spacer between the new sleeves.
Happy wrenching
Happy wrenching
20 Jan 2019 09:39
Sounds like a good plan to me.
1980 KZ550 C1 LTD
Central New York
Central New York
21 Jan 2019 19:38
I was able to get the sleeve welded; and then I spun it down on the surface grinder. It's ready to go.
1980 KZ550 C1 LTD
Central New York
Central New York
22 Jan 2019 01:26 - 22 Jan 2019 01:40
Thats not a good idea, your sleave is made out of hardened steel.
With the welding you will loss the hardness and the needle bearing rollers will destroy the sleeve surface again.
If you run out of money ask your local motor services shop for a good used VW Beatle 22 mm pistion pin.
Last edit: 22 Jan 2019 01:40 by Scirocco.
22 Jan 2019 12:41
I work in a machine shop. We knew it was hardened before we welded it. And it was sent to another shop yesterday to be re-hardened. I should have it back tomorrow
1980 KZ550 C1 LTD
Central New York
Central New York
22 Jan 2019 13:28
Well done LouisDePasquale1980KZ550C, your are a man who know the carbon/iron ratio and Brinell/Rockwell/Vickers hardness tests.
- loudhvx
22 Jan 2019 13:34
The trouble I've had when attempting things like that is that the act of welding tends to cause the piece to distort as it cools. Did you have to heat the entire piece before welding?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Scirocco
