New Shinko tire install today...ugh
  • bluej58
  • bluej58's Avatar
Re: New Shinko tire install today...ugh
11 Mar 2017 05:45
#756402
I put the rim locks back on after spinning a couple of nipples off due to some extra slippery tire lube I was using.
After a couple of changes I have figured out how to work around them, no big deal.
It's a lot easier then having to get a trailer-ed bike back home.
78 KZ1000 A2A
The following user(s) said Thank You: 650ed, GPz550D1
  • spdygon
  • spdygon's Avatar
12 Mar 2017 17:35
#756576
yes rim locks are needed on the rear....if for some reason the tire spends your valve will get cut off and end up with a flat.
also i have three sets of shinko tires and all need between 2 and 3 oz. not very well built and some are not mark to show the heavy side of the tire.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • bluej58
  • bluej58's Avatar
12 Mar 2017 19:31 - 12 Mar 2017 19:38
#756590
The Shinko 777's we bought for my wife's bike have the marks.
The Avon Roadriders I just put on mine don't :angry: I used 38 grams on the front and 41 on the back, the weights ended up opposite the stems on both tires.
78 KZ1000 A2A
Last edit: 12 Mar 2017 19:38 by bluej58.
  • missionkz
  • missionkz's Avatar Topic Author
12 Mar 2017 23:30
#756597
Performance Cycle down around
Dry Creek and I-25
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • RonKZ650
  • RonKZ650's Avatar
13 Mar 2017 20:11
#756679
Performance Cycle is a good dealer, and I've known the owner Don for nearly 40yrs. You can take what they tell you as the truth in my opinion. That said though, it still seems the tire is not a great tire if it takes that much weight to balance.
