Z1 fork swap to triumph 955i
  • JoHNY
  • JoHNY's Avatar
Re: Z1 fork swap to triumph 955i
21 Sep 2016 10:04 - 21 Sep 2016 10:05
#743090
Where are you, I have a spare set of 04 Daytona forks. They are 42mm
Seems like a Hell of a lot of work though. If you did a complete front end swap then you'll need races and bearings to go into your Kawasaki head stock. Basically there are several outlets for bearings and I'm sure you'll get the right ones. The speedo on the Daytona/ST3 is electronic so could be an issue.
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 21 Sep 2016 10:05 by JoHNY.
  • 750 R1
  • 750 R1's Avatar
21 Sep 2016 14:34
#743119
JoHNY wrote: Where are you, I have a spare set of 04 Daytona forks. They are 42mm
Are you sure they are 42mm ? , 2004 955i forks are 45mm...
  • JoHNY
  • JoHNY's Avatar
21 Sep 2016 15:29
#743125
Yeah, sorry you are right.
  • 750 R1
  • 750 R1's Avatar
21 Sep 2016 17:59
#743144
JoHNY wrote: Yeah, sorry you are right.
No need to apologize, you had me going for a bit, I thought they may have changed the tube size in the later model forks, mine are 2002...
