Bearing sizes
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Bearing sizes
27 Aug 2016 11:09
#740152
From Dan's mc site, I guess you'd need the 6204 bearings (47x20x14W) ...
Easy to find bearings in the OD x ID x Width mm format, the ones with the rubber grease seal inserts are better in wheels imo.
  • Epicface803
  • Epicface803's Avatar Topic Author
Re: Bearing sizes
30 Aug 2016 14:18
#740562
Thank you to all that replied I've gotten a bunch of valuable info on this forum as far as the bearings go I finally did enough research to find out that martin_csr was right the rim was off of a kz750 and I decided I'd rather have the correct rim so I returned it to get another rim that I had verified by the seller to have the correct bearing size it should be here tomorrow and I can move on to the next head ache
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
Re: Bearing sizes
30 Aug 2016 14:58
#740567
I have an '81 CSR1000 and both '81 and '82 LTD1000's, and I swap the rear wheels back and forth quite often when I get flats or wear out the tire on whichever bike I'm riding, so I can assure everyone the rear wheels swap directly!
  • Epicface803
Re: Bearing sizes
30 Aug 2016 15:16
#740572
I agree completely I was just sent the incorrect rim
