KZ550C LTD Fork Oil Measurement.
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ550C LTD Fork Oil Measurement.
14 Jun 2016 17:46
#731405
DANGIT! I posted the wrong file. The file above is my reorganization of the original. Here is what I started with
The following user(s) said Thank You: The_Proletariat
  • loudhvx
  • loudhvx's Avatar
14 Jun 2016 21:43
#731439
That's pretty wild. I wonder if motor oil is the same way. I've tried different brands of the same weight in my leaky car, and some brands leak out way faster, as if the viscosity was thinner.
  • The_Proletariat
  • The_Proletariat's Avatar Topic Author
  • "Cocaine is a hell of a drug"
16 Jun 2016 18:59 - 16 Jun 2016 19:01
#731696
Thank you for the chart.
Motor oil does vary from the viscosity printed on the bottle, and the viscosity does change as the oil ages in the engine. An easily noticeable example of this is how shifting gets progressively worse between oil changes. I call it "notchy" shifting.
When shifting is no longer smooth, I adjust the clutch and change the oil. Smooth shifting again.
1982 Kawasaki KZ550 LTD
Last edit: 16 Jun 2016 19:01 by The_Proletariat.
  • loudhvx
  • loudhvx's Avatar
15 Jun 2017 06:13
#764430
Since this exact subject has been brought up in this other thread, I want to put a link to it here.
www.kzrider.com/forum/5-chassis/595286-1...l-level?limitstart=0
  • LouisDePasquale1980KZ550C
  • LouisDePasquale1980KZ550C's Avatar
29 Jan 2019 19:18
#797880
The_Proletariat wrote:
loudhvx wrote: I think this has come up a few times in the past, and there was no resolution that I can recall.
It does seem inconsistent that the C model has such a high volume of oil, but such a short height-clearance measurment.
It has. There are a couple threads about this on this forum, and on other forums. Some suggest to use the height measurement, some suggest to use the fluid volume measurement.
I can offer my experience, perhaps this can be some resolution.
I rode for a week with the specified height measurement of 14''. I was afraid to ride the bike. The front end was very tight and very twitchy and there was almost zero weight transfer when braking with the front brake. The ride was terrible and I was afraid to lean in case a bump in the road upset the now nearly rigid chassis.
I drained the oil and refilled with 300ml of oil. Yes, over the spec but I can measure nearly exactly 300ml. I cannot measure nearly exactly 270 or 290 ml and I wanted the forks to be as equally filled as possible.
After this the bike feels much better. Does not bottom out even with my fat ass on the bike but it is tight enough to be confident to really push in turns. Enough weight transfer under braking to really get on the front brake. In the future I will ignore the FSM 14" height measurement and go by the volume measurement.
Possible error in both manuals?
What If the measurement should be 556mm instead of 356mm?
I feel there is a good possibility this is it. A significant amount of oil needs to be added after the initial fill of 270/290ml to reach the 14'' height measurement.
Following this info, today I used 10oz (295ml) of fork oil. The measurement with a fully extended fork and no spring is 19.75 inches.
1980 KZ550 C1 LTD
Central New York
  • loudhvx
  • loudhvx's Avatar
30 Jan 2019 08:28
#797906
That's great. Thank you for the update. That'll help others know what to do.
30 Jan 2019 08:40 - 30 Jan 2019 10:20
#797908
Deleted by Ed
Last edit: 30 Jan 2019 10:20 by 650ed.
  • loudhvx
  • loudhvx's Avatar
30 Jan 2019 09:30 - 30 Jan 2019 11:29
#797913
The manual says 356mm which is 14". The manual (at least one FSM and other 3rd party manuals) have the wrong value for Kz550C which is the bike in question.
This image is from the red base manual which covers the 1979 Kz500. It is from the appendix supplement for the 1980 model Kz550's and has a Kz550C-specific section for forks on the Kz550C model Ltd (which are much longer than the standard model).
As many users found, the measurement is way off, and does not agree with the volume. Different models/years use different volumes and distance measurements, so we are trying to narrow down a workable volume/distance value.
The white base manual (FSM) has basically the same information.
Model ...... Volume .. Height-Clearance Level
79 500B1 : 220cc : 505mm
80 400J1 : 220cc : 505mm
80 500B2 : 220cc : 505mm
80 550A1 : 220cc : 505mm
80 550B1 : 220cc : 505mm
80 550C1 : 290cc : 356mm
81 400J2 : 245cc : 520mm
81 500B3 : 245cc : 520mm
81 550A2 : 245cc : 520mm
81 550B2 : 245cc : 520mm
81 550C2 : 290cc : 356mm
81 550D1 : 244cc : 517mm
82 400J3 : 245cc : 520mm
82 500B4 : 245cc : 520mm
82 550A3 : 245cc : 520mm
82 550B3 : 245cc : 520mm
82 550C3 : 290cc : 356mm
82 550H1 : 234cc : 489mm
Last edit: 30 Jan 2019 11:29 by loudhvx.
30 Jan 2019 10:33
#797920
Loudhvx -
Very interesting; I stand corrected as I now see the supplemental information for the ā€œCā€ model. Does the bike in question have the air adjustable forks? Ed
  • loudhvx
  • loudhvx's Avatar
30 Jan 2019 10:39
#797921
650ed wrote: Loudhvx -
yes, I believe that is when all of the 400/500/550 family forks changed, when they switched over to air.
