Rear grab bar
- DGA
Rear grab bar
09 Feb 2016 11:27
No eBay APP ID and/or Cert ID defined in Kunena configurationDoes anyone recognize this grab bar set It says its from a KZ1000 ST, but any images I find, I don't see them on those bikes. I'm actually looking for a rear grab bar for my KZ1100 Spectre but they don't seem to exist anywhere, I believe it was a cast aluminium type, certainly black and not polished or chrome. The ST ones might be similar, or at least work if the Spectre type can't be found.
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
- daveo
Re: Rear grab bar
09 Feb 2016 13:12
I would guess that a 1000 ST is different, since it's a 70s type of motorcycle. just a guess.
From Kawasaki.com the part number for the KZ1100-D1/D2 Spectre frame grip is #32109-1030.
The frame grip for the 83 KZ1100-L1 LTD Shaft is probably similar, possibly identical in shape (#32109-1039).
I searched the part numbers on eebbaayy but didn't find anything.
- DGA
Re: Rear grab bar
09 Feb 2016 16:43
Thanks for that. Seems like the 1100 Spectre was a limited bike, not many spares around anymore. I know a tubular one would look wrong, even if I did paint it black. I would like one to at least be able to help lift the heavy pig up onto the center stand. There was a member on here who said he had one but is not answering his messages now.
Re: Rear grab bar
09 Feb 2016 17:14 - 09 Feb 2016 17:20Grab your wallet before clicking part number on diagram
www.megazip.net/zapchasti-dlya-motocyklo...429880#/il-245960967
$276.80
Then grab it even tighter --
www.partssweden.se/basket
6028 Swedish Krona equals 716.77 US Dollar
Last edit: 09 Feb 2016 17:20 by Patton.
- RonKZ650
Re: Rear grab bar
09 Feb 2016 17:34
Whatever that piece of Chinese metal is pictured is not off a KZ1000ST or any other motorcycle that I can dream up. The KZ1000ST just had a small grab bar on the left side for aid in lifting on to the centerstand. Always missing as most other Kawasakis of the era, as most owners opted for a luggage rack. Whatever those bars in the picture are is a big question. Maybe parts of a washing machine? Not a motorcycle part. :lol:
- daveo
Re: Rear grab bar
09 Feb 2016 18:47 - 09 Feb 2016 18:51
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
This is exactly what it looks like, and may be worth asking for measurements from the seller:
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
Last edit: 09 Feb 2016 18:51 by daveo. Reason: oops
- DGA
Re: Rear grab bar
10 Feb 2016 20:46
Oh yes, and the part number is the same, apart from the last digit, I did ask measurements, thank you for finding that, hope it's the same.
Re: Rear grab bar
11 Feb 2016 03:13 - 11 Feb 2016 03:15One digit in a part number can make all the difference.DGA wrote: Oh yes, and the part number is the same, apart from the last digit, I did ask measurements, thank you for finding that, hope it's the same.
I would ask for width measurements & the distance between the Fr & Rr mounting points.
Last edit: 11 Feb 2016 03:15 by martin_csr.
Re: Rear grab bar
11 Feb 2016 04:16
And sometimes the different part number is for a relatively minor or more cosmetic or decorative thing such as seat stitching pattern or color (eg., different color fuel tanks have different part numbers), or finish (chrome or black).
I concur with martin_csr's advice.
Re: Rear grab bar
11 Feb 2016 04:44 - 11 Feb 2016 04:47From KZQ's KZ1100 Spectre:
Perhaps someone will post a pic of the KZ1100 Spectre grab bar showing the attachment points for direct comparison with the KZ550/750 attachment points.
I suspect that the difference may be in location of the attachment points relative to the length between attachment points and shock mounting bolt.
And maybe the width between the ends.
Last edit: 11 Feb 2016 04:47 by Patton.
- aart
Re: Re:Rear grab bar
11 Feb 2016 10:10
I'll measure the attachmentpoints of my 1100 spectre grab bar tomororrow at daylight
