Question: GPz rearset pegs on 750E?
  • Nessism
  • Nessism's Avatar Topic Author
23 Nov 2015 11:11 - 23 Nov 2015 11:14
#700136
I want to install GPz750 and/or KZ700/750 L footrests on my 750E2.
Looks like the footpegs are a direct bolt-on. True?
In addition it seems the following parts are needed:
- rear brake lever
- shift lever assembly (articulated)
- sprocket cover (or add pivot stud to existing cover)
Regarding the sprocket cover, can I add a threaded hole and add the pivot stud? Any suggestions about the viability of adding these pegs to my bike is appreciated.
[IMG
Last edit: 23 Nov 2015 11:14 by Nessism.
  • Nessism
Re: Question: GPz rearset pegs on 750E?
24 Nov 2015 05:01 - 24 Nov 2015 05:02
#700266
Looks like I'm responding to myself...yet again.:)
At any rate, I'm all in on the swap. Ordered up pegs, brake lever, shift lever pivot stud, shift lever assembly, and even a sprocket cover with stud.
I'm scratching my head about that black cover with stud already attached (that's the one I bought). It's the early style cover. Kawasaki changed the shape for the '82 GPz model, which carried forward with the KZ750L model, and it's those are the models that had the rearset pegs. What model KZ used the old style cover but rearset pegs?
Last edit: 24 Nov 2015 05:02 by Nessism.
  • scubaanders
  • scubaanders's Avatar
Re: Re:Question: GPz rearset pegs on 750E?
24 Nov 2015 06:20
#700274
Nessism I wouldn't call the R1 fotrest rearsets. But as far as I remember the covers are the same but the fotrest holders differs as the R1 has the big plates for the break lever and the passenger pegs. Where you thinking of R1 after market rearsets?
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • redhawk4
  • redhawk4's Avatar
24 Nov 2015 07:04
#700283
The GPZ750R1 parts bike I had, had the pivot on the cover and the linkage moving the gear shift rearwards. I think I still have the cover, I'll look in the shed later.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
  • Nessism
24 Nov 2015 10:31 - 24 Nov 2015 12:47
#700331
redhawk4 wrote: The GPZ750R1 parts bike I had, had the pivot on the cover and the linkage moving the gear shift rearwards. I think I still have the cover, I'll look in the shed later.
This is correct. The GPz and L model bikes have the pegs about 2" more rearward. Not a huge amount, but more rearward than the regular E and H bikes.
These bikes have a more rectangular looking covers though. Still trying to figure out what model bike had the early round style cover, in black, with the stud.
Last edit: 24 Nov 2015 12:47 by Nessism.
  • redhawk4
  • redhawk4's Avatar
24 Nov 2015 12:14 - 24 Nov 2015 12:16
#700340
It looks like the boss for the lever pivot is in the silver alloy casting you have. It would be pretty easy to drill that and tap a thread for an appropriate bolt. You could even cut the head off and cross drill it to use some sort of pin or clip with a washer to keep it all in place, unless you don't want to alter your original.
As to the covers, if they are factory black isn't that from a GPz? I don't have my cover, now I think about it I think I sold that and the gear shifter and linkage to someone wanting to do what you are doing.
1977 KZ650B1
1980 Suzuki SP400
Last edit: 24 Nov 2015 12:16 by redhawk4.
  • mjg15
  • mjg15's Avatar
24 Nov 2015 20:42
#700416
Early black cover with rounded shape and lug could possibly be '81 GPz550
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Nessism
25 Nov 2015 03:11
#700430
redhawk4 wrote: It looks like the boss for the lever pivot is in the silver alloy casting you have. It would be pretty easy to drill that and tap a thread for an appropriate bolt. You could even cut the head off and cross drill it to use some sort of pin or clip with a washer to keep it all in place, unless you don't want to alter your original.
I'm considering drilling my cover but concern about controlling the position and angle of the hole. Been scheming on how to assure the hole is parallel to the existing shift shaft hole; some sort of drill guide will have to be fabricated. At the end of day I bought that one black cover for $28 shipped though. At that price it's hard to justify messing around with my cover, although I still may.
And speaking of that cover, it's imprinted with only 5 gear positions so it can't be a 550 cover.
25 Nov 2015 03:31
#700435
Nessism wrote: ...........And speaking of that cover, it's imprinted with only 5 gear positions so it can't be a 550 cover.
Those imprints always crack me up. My twisted mind envisions a new rider leaning over the left side of the bike trying to read them when shifting gears while riding. :woohoo: Ed
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
25 Nov 2015 08:29 - 25 Nov 2015 08:29
#700463
Nessism, yes the GPZ shifter can be added to the 750H & E case.
The attached picture shows a shifter from a GPZ550 added to a KZ750H (LTD) case. 750E case is the same.
The stud was removed from the 550 case and the 750 case was drilled and tapped (M8-1.0 I think, but not sure). I just center punched the location. location not critical as rod between stud and shift shaft is adjustable. I just used a drill press and hand held the case.
The "rear set" pegs are a set of passenger pegs from a 750B Twin located in the lower stud mount for the standard peg mount.
Stud unscrewed (nut on inside of frame boss) and the pegs screwed in. Spacer used to support bottomed out stud.
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Last edit: 25 Nov 2015 08:29 by Rainman.
  • Rustyhama
  • Rustyhama's Avatar
25 Nov 2015 12:34
#700515
I have the slightly rear mounted foot rests on my Z750E, the shifter pivots on the stud as you know and there is a linkage back to the gear shaft. I can take photos if you'd like a close look at the set up. I have replaced the horst links and shaft with some threaded rod, other than that it's stock I believe. Also my stud is quite worn so the whole system is quite floppy. Where did you get the new stud from?
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
  • Nessism
10 Dec 2015 05:09
#702607
Got most of the parts. Stupid footpeg rubber is split open on one side (undisclosed by the seller) so ordered new rubbers from Partzilla.
Cleaned up the brake lever and shift linkage and will post later today. Repainted the footpeg brackets too. Real happy with how everything turned out.
The engine cover from ebay needed a lot of clean up. Decided to just tap my old cover for the thread but screwed it up and the hole went in crooked. Real unhappy with myself because I made a drill jug and everything first. Oh well. Guess I'm going to have to polish the ebay cover after all.
