bleeding front brake
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: bleeding front brake
10 Aug 2015 12:05
#685261
+1 use clean brake fluid for cleaning, and penetrating oil for dismantling. Silicon should be avoided with brake parts.
The filling the caliper through the bleed nipple with a compressed piston works quite well. When the whole system is full of bubbles it is hard even to get it spongy first to bleed. A vacuum pump or even just a check valve with a long bleed hose works well in this situation.
The following user(s) said Thank You: Jbosh, kzrob
