brake rebuild kit question
- gcphoto
Re: brake rebuild kit question
03 May 2015 05:02
Correct, it was bleeder thread to be blamed. By the way what's the correct method to remove the brake piston for future reference?
'78 KZ650 SR
___________
Wear a helmet, pants are optional.
___________
- Zephyrrider
03 May 2015 18:11
Compressor is best - just make sure you put an old brake pad or small bit of wood in there to catch piston.
If you cant get it that way pump up the system a bit, add some fluid (blankets etc over paintwork )and use it to slowly get it out ,
lastly use grease
Also dont do it inside unless its your garage
lastly use grease
Mick
1994 ZR750 Zephyr C4.
- gcphoto
03 May 2015 20:05
So there's no kind of padded pipe wrench to grab and wiggle it out, eh? Seems like there ought to be.
'78 KZ650 SR
___________
___________
- Zephyrrider
05 May 2015 17:25 - 05 May 2015 17:27
Dont know if they exist gc - but i have never seen one
Regular inspection and maintainence and you will be fine
Dont go too tight with the bleed nipples
Mick
Last edit: 05 May 2015 17:27 by Zephyrrider.
