How to take springs out of forks.
  • martin_csr
  • martin_csr's Avatar
Re: How to take springs out of forks.
19 Feb 2015 06:18 - 19 Feb 2015 09:00
#662038
When attempting to push down, the caps can be stuck in place, making the job difficult. The puller should make the job relatively easy. You could use a good penetrant &/or heat w a propane torch --- forks removed from the bike, air pressure relieved & forks drained.
Last edit: 19 Feb 2015 09:00 by martin_csr.
