Rotor Bolts
  • saxjonz
  • saxjonz's Avatar Topic Author
  • KawboyZ
Rotor Bolts
01 Oct 2014 15:23
#649334
I searched without any results for a place that I could buy rotor bolts for my LTD 1000. Where is a good place to buy stuff that has the correct strengths for these type applications? Any sites or places would be greatly appreciated.
79 LTD B3
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Rotor Bolts
01 Oct 2014 15:46
#649337
Good question - I nickel plated mine at home. I'd stick with high tensile steel, no stainless here even if you can get some made so your options are limited.
  • martin_csr
  • martin_csr's Avatar
Re: Rotor Bolts
01 Oct 2014 15:54
#649339
You can probably get new rotor bolts from the Kawasaki dealer. Or RonAyers or Partzilla, etc.
I installed some nice/used rotor bolts from a late model ZX10 or ZX11 onto my 81 650-CSR.
They were virtually identical to the old KZ bolts.
Re: Rotor Bolts
01 Oct 2014 16:08 - 01 Oct 2014 16:30
#649344
No eBay APP ID and/or Cert ID defined in Kunena configurationeBay may be your best bet for new old stock. This seller has 4 sets of 2 per set. Ed
Attachment 00003b_2014-10-01.jpg not found
Last edit: 01 Oct 2014 16:30 by 650ed.
The following user(s) said Thank You: saxjonz, bluej58
  • bluej58
  • bluej58's Avatar
Re: Rotor Bolts
01 Oct 2014 17:04 - 01 Oct 2014 17:13
#649355
I new Ed would have a good idea ;)
I typed in that parts #number and Partzilla came up
www.partzilla.com/parts/detail/kawasaki/KP-92001-158.html
oops not available through Parts zilla :blush:
And so did a bunch of other places
www.speedsupplies.com/parts/kawasaki-92001-158.htm
kz900.com/hardware-bolts.htm (2nd one down)
78 KZ1000 A2A
Last edit: 01 Oct 2014 17:13 by bluej58.
  • pete greek1
  • pete greek1's Avatar
Re: Rotor Bolts
02 Oct 2014 10:29
#649412
Larry, if I were you, I would P.M. Brian ....kz10006, he always comes thru for me
Pete
The following user(s) said Thank You: saxjonz, PLUMMEN
  • saxjonz
  • KawboyZ
Re: Re:Rotor Bolts
02 Oct 2014 20:57
#649474
Thanks guys. I was looking at ads on eBay yesterday. Couldn't find a thing. Alright, well I'll order and get it done. I assume the fronts and back it's the same. I could even use the newer style right? As long as bolt is same dimensions.
79 LTD B3
  • saxjonz
  • KawboyZ
Re: Re:Rotor Bolts
02 Oct 2014 21:16
#649475
Now that I look, there is a load of parts. I think I'd to get those Allan flat head bolts. I could do the oem style too I suppose but was looking for a little bling. Literally putting parts on a few at a time. Just need to get a few nuts n bolts and lines run and bled and she'll be pretty much together.
79 LTD B3
  • John T
  • John T's Avatar
Re: Re:Rotor Bolts
03 Oct 2014 01:55
#649500
Did you try pro bolt?
Just today I was looking at Ti rotor bolts for the ZRX
True Wisdom Only Comes From Pain.
  • saxjonz
  • KawboyZ
Re: Re:Rotor Bolts
03 Oct 2014 09:23
#649528
John, are they the same size??? When I looked at pro-bolt I didn't see any of those parts listed for kz. Just the engine dress up and sprocket bolts. I really like how they look in the pictures. I would like to see those in person to see just what you get for all that money you spend. They should look perfectly polished and all. If the ZRX ones are the same size, I'm going to order those. I like the flush aerodynamic look. lol
79 LTD B3
  • saxjonz
  • KawboyZ
Re: Rotor Bolts
03 Oct 2014 09:25
#649529
Nickel plating...that sounds like a plan. I may just do that for kicks and giggles once I get things together.
Tyrell Corp wrote: Good question - I nickel plated mine at home. I'd stick with high tensile steel, no stainless here even if you can get some made so your options are limited.
79 LTD B3
  • steell
  • steell's Avatar
Re: Rotor Bolts
06 Oct 2014 14:22 - 06 Oct 2014 14:24
#649854
The Morris Mag kit for the 750 twins came with SAE Grade Five bolts, so strength is not much of a consideration. It's shear strength anyway, and that pretty much depends on diameter of the bolt. Stainless will work fine, and you can probably find them at one of the stainless bolt suppliers people use. They are just a button head capscrew, metric of course.
Just imagine the force required to shear 'four" bolts of that size, and then try to imagine your front tire being sticky enough to generate that much force.
Last edit: 06 Oct 2014 14:24 by steell.
The following user(s) said Thank You: PLUMMEN
