Upgrade to Font Duals?
- PLUMMEN
Re: Upgrade to Font Duals?
19 Aug 2014 13:19
Oh boy,here we go again! :woohoo: Ive used the 1/2" and the 5/8" style both with dual discs,never had a problem with either.
- kzdcw
- 77' KZ1000A
19 Aug 2014 13:34 - 19 Aug 2014 13:34
Hope not. Had a spare M/C I bought off ebay ( Chinese ) I believe is 14mm. Used that on my CBX years back. Seems to work fine.
Also, on my 77' Front Hub. Can it mount another Disc Brake opposite the L side where the single is? I'm assuming you remove the Dust Shield and not use the axle spacer?
77' KZ1000A
Last edit: 19 Aug 2014 13:34 by kzdcw.
- PLUMMEN
19 Aug 2014 13:41
Yes
- kzdcw
- 77' KZ1000A
19 Aug 2014 13:44
Plummen, That's kind of what I thought. I couldn't see Kawasaki making 2 different hubs.
77' KZ1000A
- StreetfighterKz
Re: Re:Upgrade to Font Duals?
19 Aug 2014 14:06
Just remove the chrome cover. There should be 4 threaded holes for a second disc already there. Btw, you still have to have the axle spacer to keep the wheel centered.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- kzdcw
- 77' KZ1000A
19 Aug 2014 14:53
Thanks Doug, Just trying to do my Homework before I get started. Just need to locate a couple of drilled discs, later KZ's I believe should work.
77' KZ1000A
- steell
19 Aug 2014 15:07kzdcw wrote: Plummen, Looks like they would. So I'm assuming the overall width of the disc and the overall height where it bolts to the wheel hub is the same? Now do I need another front wheel hub? Also, still want to use the front brake switch splitter, can I reuse mine and run 2 separate brake lines of the bottom to each caliper?
Single disk rotor is thicker than dual disk rotor, so use two matching rotors.
Yeah, you can use that damn splitter if you want, but I use a later model master cylinder that has a brake light switch bolted on. and two lines from the master cylinder, one to each caliper. Braided stainless steel of course.
ZX11, ZG1000 and lots of others use the same master cylinder, rectangular in shape with hole for mirror and it's own brake light switch. And rebuild kits are easily found.
I have 1980 KZ1000 rotors with 1983 GPz calipers and a 96 GPz1100 (same as ZX11, etc) master cylinder on my 750 twin. The master cylinder is a 15mm, and I can lock the front wheel easily with two fingers. I have no inclination at all to install a 1/2" master cylinder, as then I would have to devote to much attention to avoid locking the wheel, at a time when I have no attention to spare.
In an actual comparison between my 79 750 twin and a 84 750 Turbo (GPZ), my bike stopped 30' shorter than the 750 Turbo. And that's a lot!
YMMV, I just know what works for me.
The following user(s) said Thank You: PLUMMEN
- kzdcw
- 77' KZ1000A
19 Aug 2014 15:28
Good Advice and I appreciate your input. I like using a single brake line to each caliper too and avoid the splitter on the lower triple tree. Less chances to leak The M/C that I currently have on the Bike does have the brake light switch. I guess I could move the brake switch wires that are currently attached to the stock brake pressure switch and move them up to the master. Since they are "female" bullet ends, should be able to change them to fasten to the M/Cc switch which has just 2 flat tabs.
77' KZ1000A
- guitargeek
20 Aug 2014 18:23
5FLZ50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- guitargeek
20 Aug 2014 18:24
Sorry, still figuring out Tapatalk...
- kzdcw
- 77' KZ1000A
- Tomolu5
Re: Re:Re: Upgrade to Font Duals?
22 Aug 2014 21:51
I am running a master from a 98 zx9..works great, although I had to wire the switch. I have a dual splutter with the switch that you can have for the price of shipping. Check out my build thread as I have just completed the same swap. I am running the two different rotors temporarily as one of my duals was warped, it works great.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
