Different Rear master Cylinder???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Re: Different Rear master Cylinder???
29 Sep 2014 10:06 - 29 Sep 2014 10:07
#649109
Guys, Here's another option I think is doable ? Mounting a later Kawasaki Rear Master Cylinder with remote fluid reservoir. This ones from a 91' KZ1000 Police. At least K&L has a rebuilt kit available.
What research I came up with is that the mounting bolts (2) that mount the master cylinder to the frame appear to smaller and shorter? That shouldn't be too hard to overcome, as long as the bolt center to center spacing is the same
And the Brake Rod is different, but maybe I might be able to use mine of my 77'?
I'm hoping that some of you on this Forum has used this set-up and can provide some input. I wouldn't have this problem if there was a rebuild kit for the earlier Master Cylinders.
Attachment _12.jpg not found
77' KZ1000A
Last edit: 29 Sep 2014 10:07 by kzdcw.
  • pete greek1
  • pete greek1's Avatar
29 Sep 2014 11:00
#649112
Have you tried taking it apart & cleaning the parts in fresh brake fluid, & replacing the rubber o rings with new ones, as long as the plunger is O K, & the housing isn't scored, you should be good to go
Pete
29 Sep 2014 12:44
#649124
pete greek1 wrote: Have you tried taking it apart & cleaning the parts in fresh brake fluid, & replacing the rubber o rings with new ones, as long as the plunger is O K, & the housing isn't scored, you should be good to go
Pete
I agree! Take is apart, clean it carefully, and see what parts (if any) you need to replace. If you can't find the part needed post a question here and someone may be able to find or provide a replacement part. Ed
Attachment 00003b_2014-09-29.jpg not found
Attachment 00003c_2014-09-29.jpg not found
The following user(s) said Thank You: pete greek1
  • kzdcw
  • 77' KZ1000A
29 Sep 2014 13:22
#649126
Thanks Ed and Pete, but I've taken it apart again. Thoroughly cleaned everything again. Inspected rubber primary cup and piston. All look good? That's why I'm fielding another question about looking into a replacement Master Cylinder that I can modify a little to work.
77' KZ1000A
  • Nessism
  • Nessism's Avatar
02 Oct 2014 18:34
#649463
Finding a master that don't have a pitted bore is a real challenge. I bought several bad masters for my 750 before getting lucky and sourcing one from a friend. There are places that will bore them for you and install a stainless sleeve for about $100. I was almost about to go this route when my friend saved me.
  • Arthur A
  • Arthur A's Avatar
10 Oct 2014 13:25
#650274
My 1977 KZ650 needs to have the rear master cylinder replaced.
The mechanic said he could use one of similar dimensions.
Will look for either GSXR600 or YZF600 as shown here.
Thanks. This is helpful.
If anyone has any thoughts . . .
1977 KZ650 C1 stock
original owner
  • kzdcw
  • 77' KZ1000A
10 Oct 2014 13:42 - 10 Oct 2014 13:42
#650278
If I was inclined to replace my Rear master I would probably go with a later Kawasaki Master with remote reservoir as pictures above. Shouldn't be a big deal to fabricate a mount for the the remote reservoir and modify the pushrod. At least they have a rebuilt kit thru K&L.
Even though I was able to get my Stock master to work. I went ahead an ordered a universal "Chinese" rear master just to see if I could mask that work. As soon as I receive it, I'll report back to let the Forum members to let them know how it worked.
Attachment sku136313-6.jpg not found
77' KZ1000A
Last edit: 10 Oct 2014 13:42 by kzdcw.
