swing arm
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
swing arm
04 Jul 2006 14:50
I was wondering if I got another swing arm that is a monoshock can I have some one weld mounts for duel shocks ? It will be going on a 78 KZ1000.
- wireman
- wagonmaster69
Re: swing arm
04 Jul 2006 15:32
Don't know yet been looking on ebay seen some preaty cheep like the YZR or the older ZX9 or ZX11 but looking for all suggestions
- wagonmaster69
Re: swing arm
04 Jul 2006 15:37
By the whay this is the bike kinda ratty but it will do what you guys think?
- wagonmaster69
Re: swing arm
04 Jul 2006 15:39
- 77KZ650
Re: swing arm
04 Jul 2006 16:17
lots of stuff that will work, just look on ebay
zx arm
another one
fzr arm
gsx arm
.......the list goes on, pick one that you like, parts are easy to modify to fit
Post edited by: 77KZ650, at: 2006/07/04 19:19
zx arm
another one
fzr arm
gsx arm
07 MDP Rookie of the Year
- wireman
Re: swing arm
04 Jul 2006 18:18
Mine was in worst shape then that when i brought it home for $300.00, it will fix up nicly
1045
1045
1045
- btchalice
Re: swing arm
04 Jul 2006 20:44
kinda looks like mine when i got it
kzrider.com/index.php?option=com_ponygal...6&func=detail&id=349
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- timber
Re: swing arm
05 Jul 2006 16:25
here is another
GS1100 Swingarm on eBay
Post edited by: steell, at: 2006/07/05 20:52
Post edited by: timber, at: 2006/07/05 22:32
- StreetfighterKz
Re: swing arm
05 Jul 2006 18:24
I took a mono-shock swingarm for a 86-88 Gsxr1100 and had some mounts welded on and the arm almost slid right in. I had to do some grinding on the back of the brake pedal mount but that was the only frame alteration. With the right rim/ sprocket carrier/ sprocket combo you should be able to run up to a 180mm tire. And if you want you can swap back to the original setup without anyone knowing.
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 77KZ650
Re: swing arm
05 Jul 2006 19:47
StreetfighterKz wrote:
Post edited by: 77KZ650, at: 2006/07/05 22:48
have a 190 on the zx7 rim, its going to need a 3/8 offset front sprocket to get the chain to line up, not a big deal.With the right rim/ sprocket carrier/ sprocket combo you should be able to run up to a 180mm tire.
