Brake Caliper Compatibility
  • dejavoodo41
  • dejavoodo41's Avatar Topic Author
17 Feb 2014 09:23
#622542
I'm in the process of swapping a ZRX 1200 swing arm and rear wheel onto my "77 Kz 1000 and am having trouble finding a rear brake caliper for it. Does anyone know if there are any calipers that are compatible with the ZRX setup? I've done all of the normal searches and am coming up empty. Any info would be most appreciated.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Brake Caliper Compatibility
17 Feb 2014 10:27 - 17 Feb 2014 10:27
#622551
Pretty sure that most Zx7/9/11 rear calipers are the same. Also may look at some older Gsxr calipers. Pay attention to the bleeder location to ease bleeding.
You can also grab a PDF of EBC Brakes catalog and cross reference brake pad applications.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 17 Feb 2014 10:27 by StreetfighterKz.
The following user(s) said Thank You: dejavoodo41
  • dejavoodo41
17 Feb 2014 10:40
#622553
Thanks
  • steell
  • steell's Avatar
17 Feb 2014 14:55
#622577
I think the caliper mount brackets are different. The ZX11 has a brake stay, and I believe the ZX9 has a slot in the bracket that slides over a bar on the swing arm instead of a brake stay. The ZX7 I don't know.
Go to the kawasaki.com parts diagrams and start comparing part numbers. If the ZRX1200 has the rotating axle adjusters, then look for others that use the same adjusters (ZX11).
Why not shop eBay and the ZRXOA board for the ZRX1200 caliper and bracket?
  • DoctoRot
  • DoctoRot's Avatar
17 Feb 2014 15:03
#622579
parts on the ZRXOA for sale board are much much cheaper than on ebay
  • dejavoodo41
17 Feb 2014 15:03
#622580
I have the bracket I just can't find the caliper. I've been all over eBay and couldn't find one. I must really be losing it because I went to the Kawasaki site 3 times and and couldn't find the parts diagrams...lol
  • TexasKZ
  • TexasKZ's Avatar
17 Feb 2014 17:36
#622596
according to Kawasaki, that caliper is unique to the ZRX1200
  • dejavoodo41
17 Feb 2014 17:57
#622600
That's what I'm finding out and the cheapest one found so far is $267 so I may have to bite the bullet and dig deep and get it.
  • TexasKZ
  • TexasKZ's Avatar
17 Feb 2014 18:23
#622604
Or just skip the whole rear brake thing.......
  • StreetfighterKz
17 Feb 2014 18:25
#622605
You guys are making this way more complicated than needed. Yes, the part number is unique to the ZRX12 because of the color. But the Zx12 uses the same part number for brake pads and a cross-reference with EBC shows all the Kawasaki bikes that use the same pad.
Like I mentioned earlier, Zx7 and Zx11 calipers should work. I was wrong about the Zx9, however.
Good luck!
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: racer54, wireman
  • StreetfighterKz
17 Feb 2014 18:30 - 17 Feb 2014 18:32
#622606
Zrx1200 caliper... $89.99
Zx11 Caliper... $59.99
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 17 Feb 2014 18:32 by StreetfighterKz.
  • TexasKZ
  • TexasKZ's Avatar
17 Feb 2014 18:35 - 17 Feb 2014 18:36
#622607
Perhaps Doug is making it too simple. Just because all those models use the same pad, does not mean that the mounting holds are spaced the same, or that they all use the same brake stay. :whistle:
Last edit: 17 Feb 2014 18:36 by TexasKZ.
