Fork upgrade on KZ1300
  • Magoogle
  • Magoogle's Avatar
Re: Fork upgrade on KZ1300
06 Feb 2014 18:54
#621385
Here is mine with zx9 and zx6r swingarm. These are old photos but as you can see I had to weld in a cross-member for the mono shock mount point.
  • Kz smitty
  • Kz smitty's Avatar Topic Author
06 Feb 2014 19:11
#621389
Very nice! I like to mix up old with new.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
07 Feb 2014 15:37
#621480
kzrider.com/forum/11-projects/478810-thr...til-winter?start=840
Just scroll thru the thread.
ZX7 front with 19" KZ wheel, it's possible to get the original 1300 wheel in later model forks. :)
Les
  • Magoogle
  • Magoogle's Avatar
09 Feb 2014 09:38
#621657
problem with the 19" wheel is lack of tire support. It also depends on what your doing with your KZ1300, if you want to take corners hard then you would be better going with the 17" front.
09 Feb 2014 10:14
#621659
Be careful about changing tire size or the bike's height. The stock front tire for KZ1300 is MN90-18 which is rough equivalent to 120/90-18. A 17" tire will lower the front end by roughly 1/2". The KZ1300 has a wide engine and pipes, so unless the height of front forks make up for the lower tire things will scrape more in hard cornering. Notice pipes in pic below. If bike was lower they would be hard aground. Ed
Attachment 00007_2014-02-09.jpg not found
The following user(s) said Thank You: PLUMMEN
  • Kz smitty
09 Feb 2014 11:41
#621667
I appreciate all the input. I will probably have to sort a few things out if there is clearance issues. For my wife's sanity I kinda need to make sure I can't ride too fast. :) My last bike was a Hayabusa that I raised the rear and tuned the forks for handling. I was a bit crazy on that bike. Here's a pic for viewing pleasure. Also one pre paint and mods.
Attachment ImageUploadedByTapatalk1391974860.882807.jpg not found
Attachment ImageUploadedByTapatalk1391974874.295303.jpg not found
  • Kz smitty
09 Feb 2014 11:42
#621668
  • Kz smitty
11 Aug 2014 19:03
#643546
Attachment ImageUploadedByTapatalk1407808922.585337.jpg not found
I finally got the forks mocked up. I am using a set off of a 2001 ZX12R. So far so good! What do you all think?
  • Kz smitty
11 Aug 2014 19:04
#643547
Another pic with the tank on it.
Attachment ImageUploadedByTapatalk1407809072.039402.jpg not found
Attachment ImageUploadedByTapatalk1407809087.342540.jpg not found
  • kzz1king
  • kzz1king's Avatar
11 Aug 2014 19:17
#643549
Will you have enough clearance? Looks like rim is on same plane as bottom of frame.
Wayne
Home built KZ1000 turbo setup
  • K.D. HART
  • K.D. HART's Avatar
11 Aug 2014 19:38
#643552
I can see your going to need some fork extensions. cycle one off made a set for my bike.
You can see in the pic, they slide over the top of the fork tubes and into the top tree to add length.
[IMG
  • Kz smitty
11 Aug 2014 19:43
#643554
The forks are lowered in the pics. They came off of a drag bike. I have then torn down to remove the spacers then I will get a better feel for what I need to do. I am also going to see if I can use a little bit bigger front wheel than the stock 17". That will help as well.
