what is the purpose of a bearing spacer?
  • 80B4
  • 80B4's Avatar
Re: what is the purpose of a bearing spacer?
20 Nov 2013 14:23
#613565
Make the length of the spacer the same as the distance between the sholders in the hub and you will be good to go.
1980B4 1000
1978 Z1R
1978 B3 750
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
20 Nov 2013 14:35
#613568
this is the story of the three bears and a front wheel spacer.
the one bear said if the spacer is to long it will bind.
the second bear said if the spacer is to short it will bind.
the third bear said if the spacer is just right, all is good.
