KZ650 H2 - Fork Seal Change - What else?
  • isolatoi
  • isolatoi's Avatar Topic Author
16 Sep 2013 00:18
#606633
Hi,
I got my first bike - a 1982 KZ650 recently, and have been doing a bunch of general maintenance; I have to change my fork seals as they just started leaking badly and want to know if I should check out / change preemptively anything else while I'm changing the seals?
Thanks
Re: KZ650 H2 - Fork Seal Change - What else?
16 Sep 2013 00:23
#606634
If you pull the front forks off the bike in the process you may want to replace the original loose ball bearing steering stem bearings with tapered roller bearings. They really are an improvement and well worth changing. If you decide not to change them at least grease the old ones while you can get to them.
Also, I would definitely replace the dust shields that cover the fork seals while it's apart. If yours are original they probably have hairline cracks. Ed
The following user(s) said Thank You: isolatoi
  • TexasKZ
  • TexasKZ's Avatar
16 Sep 2013 01:57
#606639
change the fork oil, too. B)
  • martin_csr
  • martin_csr's Avatar
16 Sep 2013 02:17
#606640
Fork oil. I think the manual calls for 10W fork oil, but you could go with 15W.
Springs. The manual lists a service limit for the fork springs, so you could measure them to make sure they're within spec. Alternatively, you could get new Progressive springs.
Air pressure. The manual probably lists a standard pressure & a useable range ( ~7-14.5 psi)(not to be confused w the max pressure listed on the forks - ~35 psi which is too high - when you hit a bump, the pressure will go higher).
Or use an air impact wrench w a hardened 8mm allen socket (or brake caliper socket) -->> fork caps & springs installed.
Note: your inner fork cylinders (damper rods) may use a different size tool.
  • isolatoi
17 Sep 2013 16:04
#606811
Thanks for all the great replies!
I've got (on the way) fork seals, dust covers, bushings (just in case - a friend told be they might be going, and if they look coppery it can cause premature fork seal wear), tapered bearings, progressive shocks (for $58!), and I already have some 15w oil. Whew well hopefully after this I won't have to worry about front suspension for awhile - besides changing the oil :)
Being that I've never "applied heat" to bolts before - what is the procedure? Do I just blast them with a propane/MAPP torch? Or is it like hair dryer heat? Do I have to worry about heating the surrounding metal a bit to prevent cracking it? How hot does it needed to be heated potentially?
Daniel
  • Motor Head
  • Motor Head's Avatar
17 Sep 2013 20:50
#606848
isolatoi wrote: Hi,
Thanks
Possibly the front wheel bearings, the brake pads, and the brake fluid. Maybe rebuild the brake caliper/s. Upgrade to stainless brake lines. Hows your front tire?
  • isolatoi
17 Sep 2013 21:06
#606854
[/quote]
Possibly the front wheel bearings, the brake pads, and the brake fluid. Maybe rebuild the brake caliper/s. Upgrade to stainless brake lines. Hows your front tire?[/quote]
Front tire is good, PO got new ones very recently before I bought the bike and got new pads (I saw the receipts), was a big +. I just did the brake fluid though, it's strange they got pads but didn't change the fluid IMO. It needed it so badly, it was silty gray/black. I had to run 300ml of new fluid through the system after draining before it came out perfectly clean looking - not including the air bleed. What in the caliper might need replacing (sorry for being lazy, my service manual is still in the mail) ?
Is there a way to check wheel bearings with the wheel on? Such as blocking the engine and spinning the wheel by hand? I ask because this is my only vehicle at the moment and I'd rather have everything I need so I can knock it all out at once. I'll price them out, if they're cheap I'll grab some in case I think.
Thanks a ton, by the way!
  • Motor Head
17 Sep 2013 21:14
#606855
The front caliper has an outer dust seal that you see. But the internal seal is what holds the pressure, and also helps to ease back the piston so the brakes don't drag. Did the PO lube the Slide pins where the caliper bracket and piston housing move on the guide pins? These often get over looked, especially if they didn't change the fluid.
The wheel bearings can be felt when you have the wheel off, and the axle out, you can feel each for dryness and roughness. But the bearing/ seal kit is cheap, like $25. I'd replace them if they look old.
17 Sep 2013 21:17
#606856
isolatoi wrote: ......and I already have some 15w oil.....?
Daniel
I hope you are talking about Fork Oil not motor oil. Ed
  • isolatoi
26 Sep 2013 17:56 - 26 Sep 2013 18:42
#607916
Front fork seals and dust covers were easy and the change went great. I didn't get to the wheel bearings yet but they're in the mail and is east enough to get to. I couldn't get the steering stem nut off so the tapered roller bearings are on hold until I get a tool for that but now that I've pulled the forks off I'm not too nervous about that job.
Ed, I definitely used fork oil lol.
Motor Head, I'm assuming the slide pins have not been lubed. I'm not familiar with our kz calipers enough to know 100% what the slide pins are. Attached is the diagram from my service, are they the "caliper holder shafts" (no. 4 and 14)? In a few weeks once I have some more money I'll rebuild the calipers and replace the fluid seal (12) and dust covers (5) to prevent any water getting in and causing corrosion.
PS the forks had almost 3/4" of sludge in the bottom! Wow. This makes me wonder what else is badly in need of some TLC.
Thanks again for all the help guys!
Last edit: 26 Sep 2013 18:42 by isolatoi. Reason: Tried to attach pdf instead of image format
26 Sep 2013 18:29
#607919
Glad to read that it went well and that you found and removed the sludge. I suspect a lot of bikes are sold that have that problem. The sad part is that it can be so easily prevented just by changing fork oil every two years, and that is a very easy task. Ed
  • Samminorwich
  • Samminorwich's Avatar
16 Nov 2021 03:39
#857978
Hi can I change the seals on the forks without removing the fork tubes ?
re Samantha
