Does this shock angle look ok?
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
26 Apr 2013 23:57
#584209
Is this angle going to be ok? Plus anyone have a rough idea how much these work performance shocks will sag with a 160lb rider?
More pics here;
kzrider.com/forum/11-projects/557199-hol...=20&start=240#584206
Attachment 20130426_183214_2013-04-26.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • kzz1king
  • kzz1king's Avatar
Re: Does this shock angle look ok?
27 Apr 2013 00:29
#584212
Not sure but it looks pretty steep to me. Can you bounce on it yet to see if it moves easy?
Wayne
Home built KZ1000 turbo setup
  • kzz1king
  • kzz1king's Avatar
27 Apr 2013 00:30
#584213
kzz1king wrote: Not sure but it looks pretty steep to me. Can you bounce on it yet to see if it moves easy?
Wayne
Looked at the pic again, forget the bouncing part :cheer:
  • Cuff
  • Cuff's Avatar
27 Apr 2013 00:44
#584215
I'm thinking those would have to be some pretty strong springs even for 160lbs.
  • Dr. Gamma
  • Dr. Gamma's Avatar
27 Apr 2013 00:55
#584216
Cuff wrote: I'm thinking those would have to be some pretty strong springs even for 160lbs.
I was thinking the same thing.
Might even need some internal dampening changes too!!!
1986 RG500G 2 stroke terror.
  • Hollywoodmx
27 Apr 2013 02:17 - 27 Apr 2013 02:21
#584226
If you look they are progressive, the top few inches are a separate spring. They are for stock kz's. My gpz springs don't look that much less spaced..??
I could move them forward on the swing arm but the swing arm weld is in the way, so I can either grind the weld flat or grind a hump in my platforms.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 27 Apr 2013 02:21 by Hollywoodmx.
  • Cuff
  • Cuff's Avatar
27 Apr 2013 03:43 - 27 Apr 2013 03:58
#584228
From your picture the shock is 'lying down' past 45 degrees. That equates into more than half the energy provided by the swing arm on the up stroke into a lateral force.
Also, from your other thread the mounts you have for the right side are going to have to put up with a lot of shear force. May I suggest some bracing under them to the swing arm.
Not trying to be an ass, love the bike very much, just want to help you out if I can.
Attachment brace.jpg not found
Attachment brace2.jpg not found
Last edit: 27 Apr 2013 03:58 by Cuff.
The following user(s) said Thank You: Hollywoodmx
  • Hollywoodmx
27 Apr 2013 11:29
#584256
Thanks Cuff! Ya I was going to brace it, I was also trying to get it so part of the shock mount on the brake side was resting on the swing arm.
But I didn't know about the up force issue at all. Well I don't like the motion of being bucked so I will see what I can do today to move them forward more.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Old Man Rock
  • Old Man Rock's Avatar
27 Apr 2013 12:16
#584266
"forget the bouncing part"... No shit, details/more images on the Super Charger... B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • zukdave
  • zukdave's Avatar
27 Apr 2013 21:32 - 27 Apr 2013 21:34
#584325
When I did my swing arm swap I set the bike at
ride hight then made the strut's and mount's to fit at the stock shock angle.
At the angle you have now it will take one hell of
a stiff spring to just hold the bike up off the tire.
Then that will lead to rippin the mount's off the arm
and bending the frame mount's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 27 Apr 2013 21:34 by zukdave.
  • Hollywoodmx
27 Apr 2013 22:18
#584343
Ok how is this? Its moved before the weld.
Attachment 20130427_173657.jpg not found
Attachment 20130427_173618.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Hollywoodmx
01 May 2013 15:43
#585133
Bump
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
