Swingarms...
  • SuperMoto
  • SuperMoto's Avatar
Re: Swingarms...
28 Mar 2013 01:50
#579213
Probably would have been easier but for me this option was a lot cheaper. I mean it only took time and minimal effort. I just hope one day this bike will actually make it to the street lol.
  • Zedone
  • Zedone's Avatar
Re: Swingarms...
02 Apr 2013 03:33
#580127
Thats a pretty nice looking arm you built Supermoto! I like your elimination of the torque arm idea.
Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • racer54
  • racer54's Avatar Topic Author
Re: Swingarms...
07 Apr 2013 22:28
#581106
Found out a 2005-2006 GSXR1000 swingarm is 23.5" from center of front pivot bolt to center of axle. Not sure of the front pivot tube width but on past GSXR arms they would fit inside a KZ frame...although some adjustments would be needed to fit tight.
  • F1schumie
  • F1schumie's Avatar
Re: Swingarms...
25 Feb 2014 17:07
#623337
I'm interested to see more of your build
we are building a kz900 with an extended busa swingarm and a mono shock..
Test ride great no wiggles or shake.. Had to shim I believe welded and braced the battery no area for clearance and new rear peg mount area.. Just gotta put t back together after paint..
Can't wait to her more of your build..
  • zukdave
  • zukdave's Avatar
Re: Swingarms...
01 Mar 2014 19:55
#623814
My stock KZ650 arm vs. my 83 GPz750 arm.
[IMG
After adding 5.5 inch's making the bike 8 inch over stock w/b
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • F1schumie
Re: Swingarms...
02 Mar 2014 01:03
#623832
My bad experiences
I've seen so many extended swingarms on all different bikes and when we get them you see how dangerous they were and how hacked..
Many look and drive great but later you see stupid wheel play.. Someone used a non hardened steel washer.. Beefed one side more then the other.. Went with a single sided swingarm which was practically doomsday on the axel shaft and bearing.. Let alone trying this on a 40 year old frame..
I like the look and peoples vision but never cut any corners on your ride.. Especially if you go two up..
  • zukdave
  • zukdave's Avatar
Re: Swingarms...
02 Mar 2014 12:16
#623902
I think mine will be fine. Sleave'd with solid bar stock and a gusset at the rear cut.
[IMG
[IMG
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
