KZ 1000 A1 Single Master Cylinder
- dog pound
Re: KZ 1000 A1 Single Master Cylinder
28 Jun 2006 08:04
Let me know how much and send pic if possible to danmansfield@rogers.com
- dog pound
28 Jun 2006 08:05
The Hyd line does not run direct from res to dice, about half way down is a "banjo Bolt" splitter or T the the lines go into.
Post edited by: dog pound, at: 2006/06/28 16:41
- rattler
28 Jun 2006 21:18
is it a single disk front brake setup?
if so just run it straight to the caliper and dont bother with the t. you will have a better brake that way.
- dog pound
29 Jun 2006 02:06
So the banjo bolt is not required? OK can I run a hose or steel line. This is for a springer front end. Yes it is a single disc.
Post edited by: dog pound, at: 2006/06/29 17:18
