Allballs steering bearings for 77 kz 1000 wrong?
- Hollywoodmx
22 Jan 2013 01:29
So I was looking at the all ballz racing steering stem bearings for my kz. It lists the top and the bottom as the same but when disassembling mine the top and bottom were clearly different sizes. I want to upgrade them while I have them out but I want to make sure I get the right ones.
Any other sugesstions on a different manufacturer? I am doing a fork swap but I will match to stock bearing sizes.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- ramtough_63
Re: Allballs steering bearings for 77 kz 1000 wrong?
22 Jan 2013 01:49
I'm doing the same thing on a 78 not allot of people seemed to be chiming in I'm just gonna oeder a set and see what happens
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- testarossa
22 Jan 2013 08:50
I ordered the kit that All Balls recommended for my 78 KZ1000 A2 and it worked fine. I don't remember the specific sizes but I think the lower race was a larger diameter. I don't believe there should be any difference between 78 and 77.
Order it through Z1 Enterprises and if it doesn't work they will take it back. If you call to order they will make sure you get the right part.
BTW you will have fun removing that lower race. It's real tight in there.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Powerstroke_fan
22 Jan 2013 09:10testarossa wrote: I ordered the kit that All Balls recommended for my 78 KZ1000 A2 and it worked fine. I don't remember the specific sizes but I think the lower race was a larger diameter. I don't believe there should be any difference between 78 and 77.
Ya, thats for sure. I ended up cutting mine out. lol
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
22 Jan 2013 10:00
I installed All Balls #AB22-1014 in my KZ650. The upper and lower on mine are different sizes and all the correct pieces were in the All Balls package. Ed
- 4TheKZ1000
22 Jan 2013 10:08
call some one who knows something about the product.
Z1 enterprizes ..... 1-315-926-5054 ext 117 talk to chris..
- Jeff.Saunders
22 Jan 2013 11:45
The All-Balls kit contains 30 x 52 x 17, 30 x 48 x 14 - so I'm not sure where you are getting info that they are the same top and bottom. We have sold hundreds and hundreds of that kit - it is correct for all the early 650/900 and 1000 models.
www.z1enterprises.com
Z1 Ent on Facebook,
- NakedFun
22 Jan 2013 12:42 - 22 Jan 2013 14:02
The kit worked perfect for my bike. The only surprise I had was once you seat the new tapered races, you be hard pressed (pun intended) to get the races back out as there is really nothing to knock a drift against due to their size aligning perfectly with the pocket. If I were to do it again, before I put them in, I would use a Dremel or a die grinder and make a couple small notches 180 degrees from each other on the top and bottom "shelves" in the steering stem tube. That way, if you have to remove them, it should give you enough to catch the end if your drift on and knock them back out. Just my .02
Edit: Jeff, placed the first of what will be many orders with one of your guys yesterday. It was just as pleasant of an experience as my brother and others on this forum said it would be. Thanks for your service.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
Last edit: 22 Jan 2013 14:02 by NakedFun.
22 Jan 2013 12:46NakedFun wrote: The kit worked perfect for my bike. The only surprise I had was once you seat the new tapered races, you be hard pressed (pun intended) to get the races back out as there is really nothing to knock a drift against due to their size aligning perfectly with the pocket. If I were to do it again, before I put them in, I would use a deemed or a due grinder and make a couple small notches 180 degrees from each other on the top and bottom "shelves" in the steering stem tube. That way, if you have to remove them, it should give you enough to catch the end if your drift on and knock them back out. Just my .02
Edit: Jeff, place the first of what will be many orders with one of your guys yesterday. It was just as pleasant if an experience as my brother and others on this forum said it would be. Thanks for your service.
Cory
Good point. If I ever need to replace the new races I will probably have to use a Dremel to cut them out. Ed
- ramtough_63
22 Jan 2013 14:08
if the new tapered bearings last longer than the original.changing them wont be needed in my lifetime
while I plan on riding in my 80's only reason I'm swapping bearings now is the front end change tne original are still in great shape
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- NakedFun
22 Jan 2013 14:49
Agreed the new bearings last much longer. I only ran into the issue since my front end swap needed to be in place for the build and mockup, but was going to take them back out prior to baking for powdercoat. I have had some concerns around brinilling of the bearing races due to the 400 F temps.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- ramtough_63
22 Jan 2013 16:10NakedFun wrote: Agreed the new bearings last much longer. I only ran into the issue since my front end swap needed to be in place for the build and mockup, but was going to take them back out prior to baking for powdercoat. I have had some concerns around brinilling of the bearing races due to the 400 F temps.
Cory
makes good sense hadn't crossed my mind on the heat factor which im sure wouldnt be a problem but something else to think about indeed I'm putting my order together gonna give em a try. I'm painting my fraeme if this 2nd sergury doesnt keep me down very long
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
