zx9r forks
  • havoc97
  • havoc97's Avatar Topic Author
Re: zx9r forks
09 Jan 2013 19:33
#566610
anyone know what I need to order for bearings to do this conversion? Triples are being machined sometime within the next week, because my machinist picked them up today.
  • steell
  • steell's Avatar
Re: zx9r forks
10 Jan 2013 01:38
#566659
If the stem is long enough then you can go to All Balls site and look at the steering bearings conversion. You type in the make, model, year, of the frame and it will tell you what bearing to use for what front end. Easier to use than describe :P
The following user(s) said Thank You: guitargeek
  • donthaveakawman
  • donthaveakawman's Avatar
Re: zx9r forks
10 Jan 2013 02:15
#566661
thanks steel , that is very helpful I couldn't have found it myself
  • donthaveakawman
Re: zx9r forks
10 Jan 2013 04:04
#566666
what about swingarm? I want a wider wheel and tire but not any extra length.
  • bigcountrymoss
  • bigcountrymoss's Avatar
Re: zx9r forks
10 Jan 2013 06:42
#566674
With the zx11 forks, how would you mount a fender?
  • havoc97
Re: zx9r forks
10 Jan 2013 11:27
#566689
steell wrote: If the stem is long enough then you can go to All Balls site and look at the steering bearings conversion. You type in the make, model, year, of the frame and it will tell you what bearing to use for what front end. Easier to use than describe :P
except the 96 zx9r isnt listed as a compatible fork swap. so now Im really lost.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: zx9r forks
10 Jan 2013 12:57
#566695
:pinch: sounds like stem swap time :whistle: ,
  • havoc97
Re: zx9r forks
10 Jan 2013 14:02 - 10 Jan 2013 14:12
#566703
No eBay APP ID and/or Cert ID defined in Kunena configurationI am swapping the stem, so does that mean I just replace them with a new set of stock kz1000 bearings?
like these:
Last edit: 10 Jan 2013 14:12 by havoc97.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: zx9r forks
10 Jan 2013 15:19 - 10 Jan 2013 15:19
#566711
Yup. Stock Kz stem + stock Kz frame = stock replacement bearings. :)
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 10 Jan 2013 15:19 by StreetfighterKz.
  • havoc97
Re: zx9r forks
10 Jan 2013 16:02
#566718
StreetfighterKz wrote: Yup. Stock Kz stem + stock Kz frame = stock replacement bearings. :)
Later, Doug
Thanks. All ordered up :)
The following user(s) said Thank You: donthaveakawman
  • donthaveakawman
Re: zx9r forks
15 Jan 2013 20:09
#567548
curious if I could get a zx750-e swingarm on my kz750-h1. I know there is a conversion bearing kit for the forks available.
  • steell
  • steell's Avatar
Re: zx9r forks
15 Jan 2013 23:10
#567589
donthaveakawman wrote: curious if I could get a zx750-e swingarm on my kz750-h1. I know there is a conversion bearing kit for the forks available.
Swing arm will bolt in, and you better take a look at those conversion bearings, I think they both use the same bearings. Put a ZX750A swing arm and forks on a 79 KZ650SR a few years ago, modified the arm to run dual shock.
I don't recommend the ZX750A or E forks, no advantage to them compared to your stock forks.
