KZ650C1 Frt Master Cylinder Disassembly
- bemoore
Re: KZ650C1 Frt Master Cylinder Disassembly
05 Jul 2006 05:36
The KZ650C1 model has dual front disks. Does this change the master cylinder, and if so, are there compatible master cylinders from other bikes that will work?
77 KZ650C1 w/Kerker 4-1
- gpzrox
06 Jul 2006 02:56
To go the right way, a 5/8" master cylinder is what you should have on a dual disc application.
And you have a 7/8 handlebar, so pretty much any Jap should work, allowing for any clearance issues -- if you have non stock handlebars or such.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- bemoore
24 Jul 2006 10:56
OK. I finally got it apart. I found a pretty good set of picks at work which turned out to be the charm. Tons-o-junk in there. I cleaned it out as best I could. Then I wanted to clean the bore somehow. I found that a brass cleaning brush for a 20 ga shotgun is just about the perfect size. It might even be a little small, but I didn't want to grind too hard on it. I chucked it up in a variable speed drill and ran it very slowly mostly just to break loose any dirt stuck to the bore. I wasn't trying to remove any metal. Seemed to work.
In the resevoir, there is a plastic disk that covers the bottom and blocks access to the hole to the bore. Can this disk be removed and re-intalled? I'm sure I can get it out, but I'm not sure I can get it back in. I'm concerned that it may have been installed prior to the resevoir going on. And I don't see a way to get the resevoir off.
With all the internals out of the bore, I squirted compressed air from and to every direction I could. I reassembled it and put fluid in it and tried to bleed it with my thumb on the output to create some pressure as I pushed the brake lever in, and vacuum as I let it out. It seemed to be working. I eventually got fluid to come out. I tried this before cleaning it out and it didn't work, so I think that it is working better, but I would like to, if possible, remove that disk and resevoir and ensure that all the gunk is gone.
Thanks.
Thanks.
- rgpbeme
25 Jul 2006 20:50
On some Master cyl. the cover mounting screws are long and hold the res. on also If so just try to turn the res back and forth. It should have a o-ring on it.
I know on my 79 1000 I had to get to the chamber under the res. There were two holes that go through to the cylinder bore.
One was about 1/8" and cleaned out easy the other was about the size of a needle. It took a torch tip cleaner and some time to get it open no flushing would touch it.
Go to a site www.partnmore.com and check the brake parts. They have rebuild kits, new master cylinders, rotors. brakd pistons and shoes and more.
- bemoore
26 Jul 2006 08:22
rgpbeme wrote:
My master cylinder has a round resevoir with a screw on cover. It doesn't have any mounting screws.
rgpbeme wrote:
Thanks. I'll take a look at them and see what they have.
