Brake Systems Canniablelising Itself (SOLVED)
- wireman
Re: Brake Systems Canniablelising Itself ????
25 Aug 2012 19:05
Yeah that is strange god knows Ive had plenty of chrome stuff over the years without ever having had that happen :blink:
- BlackZ1R
- Kawasaki in my blood
27 Aug 2012 01:28wireman wrote: Make sure to soak/scrub in simple green or something like that to get all the carb cleaner out of the aluminum before painting again.
if you're worried about out gassing throw it up in a toaster oven(everybody has to have an old toaster oven in their shop, right) at about 300F for a 1/2 hour or so.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Motor Head
27 Aug 2012 09:42
Maybe some of the salt/ calcium chloride used during the winter was picked up during a wet ride? The banjo looks o be the Sacrificial anode, like the metal quality is suspect.
- 4TheKZ1000
27 Aug 2012 13:06 - 27 Aug 2012 13:13
Thanks for the help...but bike was road for the first time this month and never saw salt...its clean enough to eat off of....no contaminates on the bango or bike all parts new or reconditioned?????
Last edit: 27 Aug 2012 13:13 by 4TheKZ1000.
- Del_Herring
27 Aug 2012 13:13 - 27 Aug 2012 13:14
If there's electricity running through there, and the metal on the banjo is different than whatever it's connected to (i.e. one's aluminum, one's steel), you have the basic elements for Galvanic corrosion (same thing you see on battery terminals). I don't know much about the brake fluids other than not to mix in 5 with the older ones, but if it's conductive then it would severely speed that process.
Though I would suspect brake fluid shouldn't be conductive.
1983 KZ750-N2 Spectre
Last edit: 27 Aug 2012 13:14 by Del_Herring.
- 4TheKZ1000
27 Aug 2012 13:24
The funny thing is the old bango never caused an or this issue...its the same manufacturer, part number and looks 100% like the new one....shape, color and all. I changed the old one out do to a wire being cracked and copper exposed....think I just got a bad one.
I put on a new rec/regulator and the wire from the brake bango was lightly touching/lying on the outer cooling fin/block of the combo unit....the wire is not chafed and is brand new...but the combo unit might be transmitting engery though the wire to the bango unit...its only 1 inch from the combo unit.
I just dont know what to think..... :blink:
- 4TheKZ1000
27 Aug 2012 13:35 - 08 May 2013 00:35
Hey guys....this is why I am thinking its an electric issue. Look what it did to this chrome hose fitting and the GALvinized finish on the bango.....this took place over a two week peiod????
This is not a brake fluid issue.....you can soak a chrome fitting in brake fluid for a year and it wont do this.
Im showing both sides of the chrome fitting...one has chrome left on it the other is gone.
by the way....the brake light worked fine during this.....both pedel and front lever
Last edit: 08 May 2013 00:35 by 4TheKZ1000.
- BlackZ1R
27 Aug 2012 13:53
that's a crazy
en.wikipedia.org/w/index.php?title=Bango...nabis%29&redirect=no
. go get a new banjo and try it again. :silly:
I wonder if it is the sender unit causing the current flow?
Kawasaki
- 4TheKZ1000
Re: Brake Systems Canniablelising Itself (SOLVED)
04 Sep 2012 15:55 - 04 Sep 2012 17:21
OK solved the problem....the battery overflow is just above and over from the bango fitting that was having issues....the overflow tube came off and any out-gassing of liquid from the battery was deposited in this area. Put a new tube on and problem solved.....this is why the chrome part was chewed up.....well thats the story and im sticking to it...LOL
Last edit: 04 Sep 2012 17:21 by 4TheKZ1000.
- pete greek1
04 Sep 2012 16:12
I see a sealed battery for you in the near future !!!
- 4TheKZ1000
