Fork oil...
- lushbaugh
- everybodys a pro......
Fork oil...
08 Aug 2012 15:55
So i had forks with shit seals and sone with pitted sliders, did surgery to get a good set now i am wondering if i can use motor oil in place of shock oil just cause im so poor i cant pay attention
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Re: Fork oil...
08 Aug 2012 16:01 - 08 Aug 2012 16:04lushbaugh wrote: ... wondering if i can use motor oil in place of shock oil....
YES, perfectly okay.
And that would be new motor oil. :lol:
Last edit: 08 Aug 2012 16:04 by Patton.
- roy-b-boy-b
Re: Fork oil...
08 Aug 2012 16:04
Or transmission fluid if you are not very heavy or ride alone.
- lushbaugh
Re: Fork oil...
08 Aug 2012 16:19
Im one twenty as ive lost fifteen pounds ol lady is 100, got synthetic ten thirty and ten fourty
- roy-b-boy-b
Re: Fork oil...
08 Aug 2012 16:22
30 if that is all you have.
- bountyhunter
Re: Fork oil...
08 Aug 2012 17:32
IMHO, 30 motor oil will be way too stiff. I remember mixing motor oil 50-50 with fork oil to firm it up and it was way too stiff.
- Kidkawie
- I bleed premix
- lushbaugh
Re: Fork oil...
08 Aug 2012 20:33
I put the 30 in and its glorious. Nice and stiff but still dampens the gut shakers
Re: Fork oil...
08 Aug 2012 21:31
Don't know if equally applicable to LTD, but here's what the FSM says about 1978 KZ1000-A2:
After changing oil, pump forks several times to expel air.
SAE 10W20; apx 160 cc when changing, or 180~188 cc when dry.
420 mm (16.5") level measured from top of inner tube.
Don't over fill.
Don't over fill.
- lushbaugh
Re: Fork oil...
08 Aug 2012 22:29
My clymer said about the same except 4.5 ozs they feel right as ill pick up 20 lbs soon and i like a stiff responsive ride. It its too harsh ill change it but i needed something asap
- wireman
Re: Fork oil...
09 Aug 2012 22:51After all these years of me preaching about how great synthetic motor oil works in these front ends compared to that 10w fork oil crap somebody else actually tries it! hooray!lushbaugh wrote: I put the 30 in and its glorious. Nice and stiff but still dampens the gut shakers
The following user(s) said Thank You: lushbaugh
- lushbaugh
Re: Fork oil...
10 Aug 2012 20:22
Ive always liked my suspension practically solid for good feel of what the bikes doing and response
