single to dual discs
- damarble
02 May 2012 02:41
I'd be nice to get duals up front on the twin. Obviously I need new forks with mounts for a right side caliper. How about the wheel hub? If I take the dust cover off that side can I bolt a second disc on or will I need another hub?
I've got a line on some 89 ZX1000 forks and triples for dirt cheap. Would these introduce more headaches than solutions?
I suppose the best method would be to hold out for a complete KZ1000 front end. I've grown attached to the look of the 19" spoked wheel and don't want to lose it.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- roy-b-boy-b
Re: single to dual discs
02 May 2012 06:44
I think the easy way would be to find the old twin disk setup. Roy
- damarble
02 May 2012 11:54
Another option I'm kicking around is 2010 ZX10 forks, USDs. How big a pain might those be?
- roy-b-boy-b
02 May 2012 13:14
Unless you are going full out street fighter I wouldn't do that.
Someone will come along and give you the info you need.
Maybe start another thread with "streetfighter' fork conversion. That might get the attention you need. Roy
- damarble
02 May 2012 14:50
I don't want it to be a fighter, I just want to be able to stop and not bottom out on every little bump.
I took the dust cover off and the hub is threaded for a disc, one more step in the right direction.
Last edit: 21 Feb 2013 15:59 by martin_csr.
- damarble
02 May 2012 15:35
They definitely need a rebuild. Problem is I'm still stuck with a single disc. It's spooked me a few times already, it just doesn't have the stopping power a bike needs.
02 May 2012 23:27 - 03 May 2012 01:01Perhaps there's something wrong with the brake.damarble wrote: They definitely need a rebuild. Problem is I'm still stuck with a single disc. It's spooked me a few times already, it just doesn't have the stopping power a bike needs.
A single disc, when functioning properly, should apply enough braking power to squall the tire, which is the most possible without locking the front wheel.
Single disc are also lighter, and thereby afford significant advantages of less unsprung weight.
For racing purposes, dual discs heat up slower than a single disc.
Some folks think dual discs look cool. "Wow! Look! He must be a racer!" :lol:
Others prefer the cleaner more open look of a single disc, and to better show off those sparkling spokes.
While some still prefer the looks of a drum brake. But concede the superiority of disc stopping power (and slower heating) over even double leading shoe drum brakes.
Am just believing that not everybody's aboard the dual discs bandwagon.
(Will now take cover!) :kiss:
Last edit: 03 May 2012 01:01 by Patton.
03 May 2012 01:14
Regarding the rear brake, would suspect that drum adds less unsprung weight than disc.
When it's relatively easy to lock the rear wheel by pressing the brake pedal, whether drum or disc, other considerations besides "stopping power" would be involved, such as "looks," maintenance, heat build-up during racing, etc.
- steell
03 May 2012 01:20Patton wrote:Perhaps there's something wrong with the brake.damarble wrote: They definitely need a rebuild. Problem is I'm still stuck with a single disc. It's spooked me a few times already, it just doesn't have the stopping power a bike needs.
A few seconds thought would show you that statement is untrue. If all front brakes worked equally well, then the stopping distance of all bikes would be the same, and numerous magazine tests have shown they're not. Can your bike do a stoppie? Why not? If all brakes were equal then all bikes should be able to do a stoppie, right?
If you ever get the chance to ride a vintage racer with a properly adjusted six leading shoe front brake, you'll see just how good drum brakes could be.
No argument there. Viva La Difference! :evil:
- damarble
03 May 2012 12:32 - 03 May 2012 12:36
There doesn't appear to be anything wrong with it, it works reasonable well for what it is. Just not good enough for somebody used to dual 300mm drilled wave rotors and Nissin calipers. The rear drum is more than enough, it locks up easily. But the front takes a really solid grab to get slowing and never locks up.
I ended up buying the ZX10 forks. Even if I decide not to use them it was a good deal and I can save them for something else.
I can probably use all ZX10 brake parts if I have an adapter machined to bolt the rotors to the stock hub and space them out properly.
Last edit: 03 May 2012 12:36 by damarble.
- turboguzzi
03 May 2012 13:36
forks can be upgraded quite nicely with stiffer springs and if you want to break the bank, cartridge emulators. i usually do stiffer springs at zero cost by shortening the stock ones and adding linger spacers. stock spring rates back at that time where a serious joke, like 20-30% too soft. add a fork brace if you want a mroe solid feel
a relatively simple option to upgrade your brake would be to keep hub and fork and just fit a bigger disc + a newer caliper with and adapter to the existing fork leg holes. really not hard to do, in sohc4 forum there's a guy who does plenty of those conversions.
can fully understand you on wanting more stopping power
and ZX10 forks would look total overkill on that sweet thing IMHO.... :huh:
