Shot-filled Bars...
- wireman
Re: Shot-filled Bars...
01 Jun 2006 10:04
try a fishing weight on a piece of fishing line keep adjusting untill vibration goes away.
- FEF
01 Jun 2006 15:37
gas wrote:
I don't have anything in my KLR, but that's becasue I'm about to put on brush guards. They help with the vibration, too.
The Z1 has BBs in it, held in with RTV, if I recall correctly.
FEF wrote:Yup, this is common for the thumper crowd.
How are your bars set up?
- Pterosaur
01 Jun 2006 16:06
FEF wrote:
That's true enough...
But back in the day, most of the *thumpers* I managed to get ahold of had been rebuilt so often and so poorly that they made better paint mixers than motorcycles... You could'a set the bars in concrete and they'd still have shook your fillings out.
Did manage to wangle a ride on a sweet '67 Bonneville that had been done right. Sweet ride.
Yup, this is common for the thumper crowd....
- Kawafinity
08 Jun 2006 20:48
Try bar-snake, it's easy to use and it works, you can get it online for $29.
www.securepay.com/easyshop/products.asp?...akes&mMerch_ID=40768
- Kawafinity
08 Jun 2006 20:49
- guitargeek
09 Jun 2006 01:33
Just a thought: Has anyone tried melting lead and pouring into their handlebar?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- Pterosaur
09 Jun 2006 06:13
guitargeek wrote:
"Gee Clem, y'think it's hot enough?
:whistle: :huh: :ohmy: :blink: :woohoo:
- koolaid_kid
09 Jun 2006 07:30
I took a piece of vinyl tubing and a tube of silicone from the hardware store. I filled the tube with silicone, cut it in 2, plugged each end with a cork, stuffed 1/2 down each end of the bar, and was able to greatly reduce the vibration. No rattle, less weight, same effect.
This is similar to the bar snake, but only cost ~$10 plus a little labor.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Pterosaur
09 Jun 2006 07:39
guitargeek wrote:
While that would have an effect, part of the rationale behind shot/BBs is that a portion of the energy transmitted to the bars as vibration is absorbed by the random motion of the individual shot and converted (...conservation of energy laws, pesky physics...)to an extremely low frequency out of the harmonic range of the bars...
