shocks
- 77KZ650
Re: shocks
02 Jun 2006 18:43
new kz nut wrote:
they should turn by hand if the weight is off (ie center stand or pick up the back end), the ones on my 650 would, it just had the side stand, so lift up with one hand, and turn with the other....Now, does anyone have a shock wrench? :whistle:
07 MDP Rookie of the Year
- new kz nut
Re: shocks
02 Jun 2006 19:06
Tried that, no go, tapped them around one setting with a hammer and a screwdriver, so I know they will move, but I will need the shock wrench to turn these buggers.
I live for ebay, so I turned there first, and the cheapest one I could find was around 15 or 16 bucks, so I asked my local Kawasaki dealer and got them to order me one for less than $7.50 with tax.
Again, thanks to all of you for your support. You make a newbie feel like there is a light at the end of the tunnel. I WILL be back for more advice, I am sure, though the service manual I bought has already solved one problem for me. I hope to slowly get this thing running in peak condition, and that is going to mean new gaskets all the way through it this coming winter, as well as whatever else may come along.
Thanks, thanks, thanks! See you all again soon!
- baldtires
Re: shocks
03 Jun 2006 10:33
just traveled this road heres what i found
got some Dyna glide (02) shocks from ebay
top mount holes too big needed a bushing
bottom mount too wide
springs way too stiff,two 220 pounders barely moved them
used original springs
H.D. shocks don't have as much travel,1/2 inch or so less
i used a lathe and a mill without them this would have been a ugly ballgame
- Nevco48
Re: shocks
03 Jun 2006 11:09
I've got to ask- did you check to see if your bike still has the little tool kit crammed under the seat near the battery? Very often you can find a cheesy shock wrench in there.
- new kz nut
Re: shocks
04 Jun 2006 09:18
No tool kit under the seat - as a matter of fact, I am already getting one together to go under there, as the straps are still there and in good condition, but no shock wrench there, cheesy or otherwise.
I got one from my local dealer, opened it, went outside the dealer to check it, and it doesn't fit. What the -?!?! :blink: Had them order me the slightly more expensive (twice the price, grrr!) adjustable wrench, should be here beginning of next week, so hopefully this issue is all settled. I have to say, though that I am not 100% sure that I have completely solved this kaka - could it really turn out to be as simple as a wrench? LOL
Will post again when I find out...
Post edited by: new kz nut, at: 2006/06/04 12:19
- Vter Bob
Re: shocks
04 Jun 2006 10:17
Go to Sears, buy a strap wrench, works just as well...
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
