Making rubber parts
- bluej58
Making rubber parts
12 Feb 2012 21:16
I'm not crazy, :dry:
I know that most of the off the shelf rubber parts are better and cheaper than I can make them for .
But some things like the foam cushion under the gauges and the bumper on my kick stand are not available through Z1 E.
What do you guys use for these things or other hard to find parts ?
JD
JD
78 KZ1000 A2A
- z1kzonly
Re: Making rubber parts
12 Feb 2012 21:35
Gauges use this rubber foam padding. Any Industrial supply source has it.
Any big factory, parts room, etc.
I might have a kick stand rubber, if these are correct.
My stash, soaking in "WellWorths" "Dazzle" product. Similar to armor all.
Great stuff for restoring!
- z1kzonly
12 Feb 2012 21:46
I can't remember, the last stock 4 into 4 exhaust system I had was in 1978. Before I cut the pipes in half to go drag racing.
That exhaust rubber bumper might have been square or rectangular???
True purists let us know please.
- testarossa
12 Feb 2012 22:31
Don't just automatically assume that Z1E doesn't stock your part because it isn't listed on the website. Those guys are masters at tracking down parts, and they will order OEM parts if necessary or point you to another supplier if they cannot get it. It's worth a phone call. That's what I always do.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
12 Feb 2012 22:33bluej58 wrote: I'm not crazy, :dry:
JD
The mainstand bumper (see part #25 in drawing) is listed as still an "Active" part on Kawasaki.com so any dealer can order it for you. Ronayers.com shows the price as $2.08. Ed
Attachment CenterstandRubber.jpg not found
- bluej58
12 Feb 2012 22:55
Cool Ed .
I did ask Z1 about the gauge cushion , they don't carry it.
I'll hunt down some of that foam rubber.
Thanks everybody.
JD
Thanks everybody.
JD
78 KZ1000 A2A
Last edit: 19 Feb 2013 12:43 by martin_csr.
- Kidkawie
- I bleed premix
13 Feb 2012 11:51
I used some plumbing washers for my gauges.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
13 Feb 2012 12:11
For the cushion you may be able to cut some from a cheap thin mouse pad. As long as it is closed cell foam (so it won't absorb water) it should work ok.
- bluej58
13 Feb 2012 22:10
I went shopping today and found a kitchen floor mat that was about 1/4 to 5/16 " thick and made of a compressible neoprene type material with a lovely floral pattern on a PVC type skin.
Unfortunately it was made in a country I try not to support, but I'm on the right track.
78 KZ1000 A2A
- jonnybravo
- Banned
13 Feb 2012 22:30testarossa wrote: Don't just automatically assume that Z1E doesn't stock your part because it isn't listed on the website. Those guys are masters at tracking down parts, and they will order OEM parts if necessary or point you to another supplier if they cannot get it. It's worth a phone call. That's what I always do.
+ 1 ON THAT, they put me on to someone once that had an impossible to find part
- nobody
13 Feb 2012 22:32
i am an upholster by trade i can all most say with out a doubt at least i think a full server foam shop would have something.a lot of things i do are custom ,and i look around a lot for just the right thing to do a job. this is not a kaw but did this 3wheller 2011 kind of plain jane but dont look to bad for an old guy that dont walk to good any more.
Attachment Picturesall261.jpg not found
