- Thank you received: 507
Touring tire and shock recomondations for a kz1000
- bluej58
22 Jan 2012 16:09 #499418
by bluej58
78 KZ1000 A2A
Touring tire and shock recomondations for a kz1000 was created by bluej58
I live out in the country and plan on using the bike for a lot of highway travel so I'm looking for a set of tires and shocks that will be good for long rides but are still decent for cornering.
I have spoke tires so they will need tubes.
Any suggestions would be appreciated.
Thanks,
JD
Thanks,
JD
78 KZ1000 A2A
- Thank you received: 2832
22 Jan 2012 18:55 #499442
by 650ed
Replied by 650ed on topic Touring tire and shock recomondations for a kz1000
I'm using Hagon shocks, Pirelli Sport Demon tires, and Metzeler tubes (as recommended by Pirelli). They work great and any speed, and the tires are holding up very well so far (about 4,000 miles). I'm really happy with this combination! Ed
davequinnmotorcycles.com/cgi-bin/webc.cg...GON_TWIN_SHOCKS.html
www.pirelli.com/tire/us/en/motorcycle/sh...rl=%3Fsubtype%3Droad
- faffi
- Thank you received: 36
22 Jan 2012 19:04 - 22 Jan 2012 19:08 #499443
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic Touring tire and shock recomondations for a kz1000
It's hard to get better value for money than Ikon shock absorbers, but Hagon also have some shocks with adjustable damping for a fair price. If you want to support local industry, Progressive Suspension have decent products, but they cost a bit if you want adjustable damping and the ability to rebuild them.
The good thing about adjustable damping is that A) you can compensate for wear and
you can adjust them to suit your riding at the moment. Cruise gently and you can dial in the least amount of preload and damping. Want to go crazy around the corners? Add preload and damping for added cornering clearance and control.
I think you will be hard pressed to find a better compromise than the Metzeler Marathon ME88 for the riding you describe. I know tyres are like engine oils; everybody have an opinion. And it's highly subjective. Also, a tyre that works with one riding style and/or bike may not work so well for another combination. Still, the Metz is a high quality tyre that gives lots of miles while offering more stick than your bike has cornering clearance. And it's also quite respectable in the wet.
EDIT: The Pirelli suggested by Ed is a higher performing tyre for serious scratching, but tyre life will be noticeably less. Personally, I prefer high grip over long life, but if I ever were to go on a long tour, I'd take the 3 times extra mileage of the Marathon.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Last edit: 22 Jan 2012 19:08 by faffi.
- mark1122
- Keep twisting it
- Thank you received: 109
22 Jan 2012 19:05 #499444
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Touring tire and shock recomondations for a kz1000
i run Dunlop Roadsmarts .they have superb grip. i use them for track days too. Not sure if they are avail in kz size though , since i run dif rims.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bluej58
23 Jan 2012 01:46 - 23 Jan 2012 01:56 #499550
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Touring tire and shock recomondations for a kz1000
I looked up everyone's suggestions and I'm Finding 18" rear tires are not available in Dunlop road smart or Metzeler Marathon ME88 unless I'm confused which I know I am.
Hey Ed, those Pirelli Sport Demon's are looking good.
Just for fun I looked up Carlisle Tour Max which is what I was running and it's still available but only for golf carts :silly:
Thanks everybody,
JD
Thanks everybody,
JD
78 KZ1000 A2A
Last edit: 23 Jan 2012 01:56 by bluej58.
- faffi
23 Jan 2012 19:27 #499673
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
One of many sources
www.americanmototire.com/catalog/product...php?products_id=3588
1977 KZ650B1
1980 F1 engine
B1 Points ignition
23 Jan 2012 19:50 #499677
by 650ed
- bluej58
25 Feb 2012 17:38 - 25 Feb 2012 17:40 #506300
by bluej58
78 KZ1000 A2A
It's time to buy tires and so far the only matching sets I have found are Michelin Pilot active though
www.ronayers.com
And Avon AM 26 through www.motorcycle-superstore.com
The Avon's front tire is almost a 1/2" thinner that stock.
I have more places to check.
From what I'm told the Pirelli Sport Demon's are not available for my stock rims :S
Ed, don't you have a 19" front and a 18" back ?
If anyone has an opinion on either sets of tires, or a line on another brand that will fit my stocker please let me know.
Front 3.25 x 19
Back 4.00 x 18
I plan on pulling the trigger before the end of the month.
Everyone seems to have sales going on right now.
In the mean time I'm cleaning and truing the wheels .
This is the way the shop I went to years ago used to do it, see any problems with doing it this way ?
JD
Front 3.25 x 19
Back 4.00 x 18
JD
78 KZ1000 A2A
Last edit: 25 Feb 2012 17:40 by bluej58.
- mark1122
- Keep twisting it
25 Feb 2012 18:12 #506308
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
i have used Metzler lazertechs. they were good.
www.us.metzelermoto.com/web/catalog/moto...atalog/sport_touring
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
25 Feb 2012 19:18 #506316
by 650ed
I’m running a Pirelli 100/90 V 19 Sport Demon on the front and a 120/90 V 18 Sport Demon on the rear. I am using Metzeler tubes; these were recommended by Pirelli (a Metzeler business partner) because Pirelli doesn’t offer the tubes in the sizes I need.
Ronayers code for the front is 871-2096 @ $95.14; the rear tire is code 871-2115 @ $102.71. At the link below click on the drop-down menu to the right of the picture of the tire.
www.ronayers.com/ProductDetails/N/10023/SKU/1652548
26 Feb 2012 12:14 #506426
by 650ed
bump
- bluej58
26 Feb 2012 14:00 #506443
by bluej58
78 KZ1000 A2A
I'm calling Ron Ayers back tomorrow and asking why they didn't come up with the Pirellis ?
The Metzler's look sharp too, but if I have a choice I think I'm going to give the Sport Demons a shot.
Thanks guys
JD
Thanks guys
JD
78 KZ1000 A2A
