how do i put 2000 R6 triple tree on my 650
  • ramtough_63
  • ramtough_63's Avatar
Re: how do i put 2000 R6 triple tree on my 650
05 Jan 2012 23:16
#496615
+1 on the pic's its better than porn for us old guys
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • KzJim
  • KzJim's Avatar
06 Jan 2012 00:02
#496626
531blackbanshee wrote: unobtanium for a stem ?
why?
Why not.. it's trick, light, strong and expensive... I have been asked to make a few parts in Ti and then the guys get the price tag and they don't seem to need it anymore. LOL
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • steell
  • steell's Avatar
06 Jan 2012 00:44
#496631
By the way, smclem has front and rear suspension with wheels off a R6 (I think) listed in the For Sale section, and he's only asking $250 for it.
2005 Model
Right Here
  • 893cv
  • 893cv's Avatar
06 Jan 2012 21:55
#496819
R6 forks, sure. R6 triple on a kz650, not so much. Your KZ650 has 60mm of triple clamp offset, and a 2005 R6 has 30mm of fork offset. Thats a HUGE change and a formula for very slow handeling. Irishwill has made triples with stock (KZ1000) offset so correct triples have been made. You may want to send him a PM about this swap.
Good Luck,
Jon
1980 kz1000 LTD
1978 Z1R
  • jeffasaki
  • jeffasaki's Avatar
06 Jan 2012 21:58
#496822
have you tried a bungie cord?
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • steell
  • steell's Avatar
07 Jan 2012 13:51
#496913
jeffasaki wrote: have you tried a bungie cord?
Great idea! You could even put a ratchet on the bungie cord and make it adjustable!
  • acoustictp
  • acoustictp's Avatar Topic Author
08 Jan 2012 11:07 - 08 Jan 2012 11:08
#497047
I got the front done it was simple after i got into it i just had to swap out the bearing the stem was long enough on the r6 but the r6 swing arm is way to wide to get in the kz its over a inch to wide now the search is on for a swing arm that will fit it
Last edit: 08 Jan 2012 11:08 by acoustictp. Reason: no pic
  • steell
  • steell's Avatar
08 Jan 2012 15:33
#497079
Do you already have the rear wheel you will be using?
I can tell you that a 83-85 GPz750 aluminum swing arm is an easy fit to the 650 frame, has a 17mm axle, easily modified for dual shocks (if desired), and will take up to at least a 4.5" rim with 160 tire. I have used them on a dual shock KZ650 SR, dual shock 1980 KZ750E, and a monoshock 1980 KZ750G twin.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
09 Jan 2012 11:26
#497214
acoustictp wrote: I got the front done it was simple after i got into it i just had to swap out the bearing the stem was long enough on the r6 but the r6 swing arm is way to wide to get in the kz its over a inch to wide now the search is on for a swing arm that will fit it
glad it worked out so well for you.
keep us posted on the rear.
