replacing spokes
  • aafadca
  • aafadca's Avatar Topic Author
replacing spokes
24 Dec 2011 23:50
#494584
My spokes on my 76 kz900 are pretty worn/rusty and I'm wanting to replace them. Is there anything special or difficult about doing this? I think I'm going the stainless route. Thanks
1976 kz900
  • bluej58
  • bluej58's Avatar
Re: replacing spokes
25 Dec 2011 12:39
#494621
I'm considering going stainless also,and was thinking that it would be easiest to do them one at a time.
I plan on doing a lot of research on it first, starting here ;)
78 KZ1000 A2A
  • z1kzonly
  • z1kzonly's Avatar
25 Dec 2011 14:13
#494633
Are The Rims and Hubs nice enough to leave alone?
Stainless are the way to go. They are over a $100 a set! Buchanon's
I guess you could save money by not having them trued afterward. If you replace 1 at a time
you better have some valium with your patience. I have this old project wasting away, at least the spokes will look good forever :woohoo:
Attachment HotRod003.jpg not found
  • aafadca
25 Dec 2011 21:25
#494660
Yeah. I thought doing them one at a time would be the best way to go if I did them myself. Is that not a good idea?
1976 kz900
  • donthekawguy
  • donthekawguy's Avatar
26 Dec 2011 00:40
#494675
I don't think you can do them one at a time because they are too long to take out and get back in. Take some pics and you should be fine. Remember you might have to replace the nipples also, but it's a good time to clean up the hub!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • DoubleDub
  • DoubleDub's Avatar
26 Dec 2011 01:11
#494679
I used a greeny/some WD40 and some elbow grease to clean mine up. After that you can polish them with a metal polish like mother's or mequiars if you are into that. Probably be less work than replacing them with stainless unless you've laced a wheel before (coming from a guy who has never laced a wheel before).
  • zukdave
  • zukdave's Avatar
26 Dec 2011 14:12
#494729
Not that hard to do lacing a wheel.
I put a ziptie were the spoke's cross then
pull the nipple's.
replace two at a time and set the hub/spoke
combo in the rim and the spoke's line up.
Just did this one that way.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Kapahulu
  • Kapahulu's Avatar
26 Dec 2011 15:20
#494734
zukdave wrote: Not that hard to do lacing a wheel.
pull the nipple's.
Great idea Dave! I've been planning to do a spoke change (for the first time) and this will help to keep things simple.
2strokeworld.com
  • aafadca
26 Dec 2011 15:50
#494739
Sounds simple enough. Any more ideas anyone??
1976 kz900
  • bluej58
  • bluej58's Avatar
26 Dec 2011 18:32
#494754
Dave,
I'm confused as to what the zip tie does for you :huh:
But doing two at a time sounds like a good idea.
JD
78 KZ1000 A2A
  • zukdave
  • zukdave's Avatar
27 Dec 2011 09:33
#494827
JD the zip tie hold's the pattern
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • TexasKZ
  • TexasKZ's Avatar
27 Dec 2011 13:20
#494844
Here is a pretty good description of the next step.
www.my68flh.com/2009/05/14/how-to-true-spoke-motorcycle-wheels/
